Jim Thompson
Id like to convert six 3.3v level signals to 28v signals. Very low
current.
I've found some ICs, but they only convert 1 signal each and they
internally generate the 28V.
Since I have 28v going into the board, I really dont need the IC to
generate or charge pump from the low to high voltage. Im just looking
for an IC that takes the 3.3v signals and switches it to 28V when 28V
is provided to the IC.
How can I do this??
Open-collector voltage comparators. View in Courier:
Vcc
| +28
[R1] Vcc |
| | [10K]
| | >--+-->OUT1
IN1>----|----|+/
| U1A +28
| LM339 |
| [10K]
| | >--+-->OUT2
IN2>----|----|+/
| U1B +28
| [10K]
| | >--+-->OUT3
IN3>----|----|+/
| U1C +28
| [10K]
| | >--+-->OUT4
IN4>----|----|+/
| U1D +28
| [10K]
| | >--+-->OUT5
IN5>----|----|+/
| U2A +28
| LM393 |
| [10K]
| | >--+-->OUT6
IN6>----|----|+/
| |U2B
[R2] GND
GND
For R1 and R2, set the ratio so that the voltage at the inverting
inputs of the comparators is halfway between Voh and Vol of your
logic.
Use opamps, get active pullup, less parts, and possibly less power
consumption, depending on how hard the load needs to be pulled up,
which isn't specified here.
John
Got a 28V rail-to-rail-output device in mind, John ?
...Jim Thompson
