I apologize if I have posted this on the wrong page. I have recently bought a set of rear lights for my truck. The leds are not very bright though. Would it be possible to change them to brighter ones? The truck is on a 12v circuit and there are 45 leds per side so 90 total. I assume that the resistors drop the voltage? Could I replace the resistors with wire and put in 12v SMD's? The maximum diameter is 5mm, but i can easily drill the holes out to 7mm and the maximum height would be 25mm from the circuit board as the cover gets in the way. Also what is the best way to remove and replace the leds, I only have an antiquated soldering iron which I used to remove one of the leds to see if it had any info on it and it was not easy.
Any help and advice is welcomed as i have a very limited knowledge on this subject. Thanks.
