Hello there.
I want to run one LED SMD using solar battery with below specifications. Does it seem right ? And of course I have to reduce the voltage in order not to fry the LED. What Do you suggest ?
LED SMD Specifications :
Wattage : 10
Voltage : 9-12
Current : 900 mA
Solar Battery Specifications :
Maximum Output Wattage : 10
Output Voltage : 18 volt
Output Current : 560 mA
* I also have a solar battery with 5 wattage output and 280mA output current and 17.56 volt output. Is it able to run the LED SMD ?
Wattage : 10
Voltage : 9-12
Current : 900 mA
