LED lights dimming after several minutes
Hi, I installed an LED strip for my kitchen counter. Since I'm living in an apartment, I didn't want anything too permanent, so I decided to to power the LED strip using rechargeable batteries.
The power specification for the LED strip is 12V DC. Since rechargeable batteries (AA) are 1.2V, I used 10 batteries. When it powers on, the LED strip will be at the regular brightness that I would expect. However, I've noticed that after several minutes, the light output would dim.
Would using rechargeable batteries be causing this? I can go out and buy 10 regular AA to test it, but I wanted to check here first to see if anyone has an answer.
The voltage seems perfectly fine for the application.
How long is the strip? The smd leds may be small but can consume alot of current if your running a few meters.
I recently brought a 5m strip myself, which consumes 12v, 5A! If I used batteries I would experience the same issue your having.
It might be more practical to use a dc adapter, rated properly. But you need to know the current draw of your strip first.
If you know how many leds are in the strip you could find out the current draw that way.
Let's say 100 leds at 20mA:
100×0.02=2A
Then a 12V, 2A adapter would be suitable. It's a more permanent than batteries but at least they won't discharge after a few hours.
Same led type as I have! Those 300 leds consume 2A.
So a 12V, 2A adapter or higher current is needed.
I think your batteries setup might discharge about every 10 hours. Depending on there current rating.
Still I would recommend a DC Adapter, these are really common 12v, 2A so you might find one knocking around the house.
Great, thanks for the information. I guess for regular used lights that are one for a while should probably be plugged in.
Sorry can you explain that again?
Ash (sadlercomfort) gave a very nice explanation of what power supply to use.
You can go a little further and buy/use a supply that has a higher Amperage output. Like a 3Amp to keep it cooler.
Martin
