LCD Number on Signal Generator has a line out
W
W. eWatson
Back if this post works. I'm having trouble posting.
OK, I have a BK Precision signal gen, model 4011. I've had it for about
5 or more years, and barely used it. I do mean barely. The power cord is
still wrapped up as it originally was. I tried it on my Oscope, and it
is working. In fact, a year ago I took it to an amateur who was capable
of evaluating it with Oscope. It worked fine. I've done zip with it since.
When I turned it on to run it into the Oscope, I found that a digit is
failing. There are four digits, maybe some small version for a decimal
point. When the leftmost digit is a 3, for example, the middle line is
out. It looks like a backwards cap C.
I plan to sell this, and is there any simple repair I can make? Maybe I
just need to leave it on for a few hours. I was about to sell a Plymouth
van last year, since we had no need for it. It had been sitting for
almost a year with just a few drives here and there. When I checked it
out before sale, it had some issues, minor, but annoying. As I began to
use it more, it got better. I still have it and drive it once a week,
and use it for bi-monthly 500 mile excursions to San Francisco/San Jose.
Might work with the gen. Comments?
G
Grant
Depends whether the contacts are corroded or vibrated off, or LCD just
needs a wiggle in the socket. Open up the thing to see how the LCD
glass is connected. Give it a wiggle, unplug/replug.
If it's in a housing pressure mounted against a PCB you may need to
disassemble, clean contact area on PCB, reassemble. If it's been wet,
you have corrosion to deal with, depends what you find inside the thing.
Grant.
W
W. eWatson
Grant.
Thanks. Sounds like a plan.
W
W. eWatson
I opened the device and poked around with a eraser on a pencil to no
effect on the 5-digit display panel and wires leading to the display.
There is zero aging and dust inside. It's been in a cardboard box for
quite a long time. I did leave it all on for about 8 hours but that
didn't change anything.
I called the mfger for a part no. They had none, but did have two in
stock simply called the display unit. The device is 7 years old and not
mfgered any longer, although there is a 4011B. $25 for the part. I
planned to sell this. I'm not sure the sales price warrants the
expenditure or my effort to fix it.
