you are correct, new ones are ridiculously
cheap when you compare with a few years back.
In this application, the problem with new monitors is that pretty much
all are now wide screen,
this might possibly be a problem with arcade/older console game
(stretched picture), use
unless you can be sure that the picture can be set to 4:3 (in the
monitor, rather than in Windows or the PC) and not stretch and
distort.
Even if this isnt a problem, another issue may be physically fitting a
large widescreen LCD monitor into an existing arcade cabinet (to get
the same screen area that was used with the original CRT) that would
have been made for a 4:3 CRT screen (I dont know if the OP is
planning on doing this). Also if there is existing artwork/bezel
involved, this presents further problems to consider carefully.
On the other hand, these things might not be a problem, depending on
OP's preference and plans, but are worth considering before running
into problems after buying monitors etc.
So just buy a 19" 4:3 LCD screen for well under $200 new then. They ARE
still available, (maybe not for much longer, but your list of problems is
definitely premature)
Hell you could even buy a brand new 17" 4:3 LCD a few months back for $100
new, but I think they are all gone now. I'll sell mine for that though.
MrT.
