I have an idea, and the question is Does someone already make a product to do this?
Garage ceiling light is bright enough for most things, but sometimes I'd like a lot more. I don't want to run a new line to a second wall switch, or have a pull string. And, I've got a basement full of parts.
The idea is to have a controller sitting on the switched AC to the existing light. If it sees an AC dropout of less than 1 second, it enables a TRIAC or SSR to power a second light downstream.
Turn on switch - original light
Quickly turn switch off and on again - both lights
Turn switch off and on slowly - original light
Off is off - the original light goes off when flicking the switch to enable the second light. The controller has enough energy storage to keep its logic alive for one second. If power is off longer than that, it comes up reset (second light is off).
Add a 4017 and some jumpers, and the same technique could run up to 9 lights in a string.
The 4017 part probably is too complex for a commercial product, but I would think a single stage controller would be pretty handy, particularly in spaces like a garage or basement. I've got the circuit worked out; my question is if something already does this?
Thanks.
ak
Thanks.
ak
