Phil Allison
I tested a 75W Osram clear lamp & a 70W No Frills halogen (claims
100W equivalent) - the Osram measured 54ohms and the halogen 56ohms.
On 240V, the Osram drew 325mA and the halogen 302mA.
The resistance rises are 13.7 times and 14.2 times = essentially the same
filament temps.
However, the filament in the Osram is longer by about 40% plus the wire is
also slightly thicker.
Now, light output is proportional to surface area for equal temps, so the
Osram
MUST deliver more light.
Putting each lamp inside a white, 15cm spherical ceiling fitting and using a
DSE lux meter - I found the Osram put out fairly even light in all
directions
while the halogen is uneven and quite poor in the downward direction.
Dunno which is brighter overall - SFA in it really.
Except one is banned and the other is legal ......
.... Phil
filament temps.
Osram
directions
.... Phil
