Tristar
Kids Bike Timer circuit not working, Why?
OK, I checked and double checked all my solder joints and can't find
anything out of place or poorly soldered. I ran a check on the 555
timers before adding them to the board. All IC's are soldered directly to
the board. This is a two sided board and I found it about impossible to
solder a IC socket on both sides of the board.
Here's what I'm doing and here's what is happening/not happening.
Depress SW2 once, LED lights up. (this is an indication that the missing
pulse detector is working) As long as SW2 is pressed once every few
seconds the LED will remain lit. (SW2 will later be replaced by a reed
switch triggered by a magnet attached to the wheel of the child's
exercise bike.)
OK, I press SW2 and then SW1 (SW1 should start the countdown) and then
keep pressing SW2 every few seconds to keep it active.
What is supposed to happen at 30 seconds is that contacts at CN1 are to
close triggering a small prerecorded voice chip announce the successful
completion of 30 seconds of pedaling. 30 seconds later CN2 should go off
etc..
I can successfully set the length of time the missing pulse detector will
tolerate with the pot at R12.
Nothing else seems to happen. I've got power and ground to the IC's. I
did notice the two 555's get warm but not real hot.
Any ideas? I'm not sure where to start troubleshooting this.
I'm posted a capture of the board and the schematic John Fields and the
rest of you have helped me put together
at alt.binaries.schematics.electronic
Thanks for your patience here!
Lawrence
exercise bike.)
etc..
Lawrence
