On Nov 20, 7:59 am, Fred Bartoli <" "> wrote:
Winfield a écrit :
Fred Bartoli wrote:
Jim Thompson a écrit :
Fred Bartoli >
D from BC wrote:
[snip]
Except for the "sweet spot" bias condition, gain (small signal)
and output Q-point probably vary independently.
Are you sure that they are independent?
For a given jfet model gm is strongly linked to the drain current
(and essentially free from IDSS).
They're not "independent", but I don't think incremental gain
and bias Q-point will exactly track.
Ah, a bit of french meaning slept in there.
Now you said they'd probably vary independently, which they don't
(for ex.
http://www.alldatasheet.com/view.jsp?Searchword=2SK170).
But gain and bias point sure can't exactly track. For this to be
so, you'd have to have gm proportional to Id, which you can't
ignore to be the hallmark of exponential
Well, as I understand it, and based on my measurements as well,
gm does mostly track Id, more or less independent of Idss,
especially at currents well below Idss. But I don't get the Q
discussion y'all are having here. To my mind the Id operating
point is best set independently from the particular miserable
JFET's Vgs vs. Id, etc. I mean, part-to-part, sheesh! Bummer!
I'm not arguing about "Q point". Just about gm dependency on Id.
I totally agree about the almost non dependency of gm on Idss and that
gm is mostly tied to Id for a given fet model (hence biasing is best
done by setting Id).
But gm doesn't track Id. I mean gm isn't proportionnal to Id, but rather
to sqrt(Id). Ok at very low current in the subthreshold region Id
becomes exponential, but this isn't the usual way of using jfets,
specially when we want low noise.
Yes, Fred, thanks, when I say track Id, I am thinking
of low currents, because I'm usually using large-die
parts, with 500mA Idss, etc., at "low" currents like
5mA, etc., where they act more like BJT transistors,
with Id vs Vgs exponential, as you say, and gm ~ Id.
I'd better not go further out on the proverbial limb,
not having my measured data in front of me.
