D from BC
Fred said:Jim Thompson a écrit :Fred Bartoli >
D from BC wrote:[snip]
Except for the "sweet spot" bias condition, gain (small signal)
and output Q-point probably vary independently.Are you sure that they are independent?
For a given jfet model gm is strongly linked to the drain current
(and essentially free from IDSS).They're not "independent", but I don't think incremental gain
and bias Q-point will exactly track.
Ah, a bit of french meaning slept in there.
Now you said they'd probably vary independently, which they don't
(for ex.http://www.alldatasheet.com/view.jsp?Searchword=2SK170).
But gain and bias point sure can't exactly track. For this to be
so, you'd have to have gm proportional to Id, which you can't
ignore to be the hallmark of exponential![]()
Well, as I understand it, and based on my measurements as well,
gm does mostly track Id, more or less independent of Idss,
especially at currents well below Idss. But I don't get the Q
discussion y'all are having here. To my mind the Id operating
point is best set independently from the particular miserable
JFET's Vgs vs. Id, etc. I mean, part-to-part, sheesh! Bummer!
But anyway, whatever, I suggest that D just go ahead and use a
JFET opamp. I mean, I'm a "big" fan of JFETs and use them as I
can, for when they're best, but what an unholy pain they are!
Well..If I've posted anything goofy about JFET's, it's probably
because I've forgotten them.
I usually dodge discrete transistors and use op amps instead.
But..this time around, a JFET looked like a good fit.
It did the following:
Low noise
Impedance transformation
Level shifting
Below rail small signal amplification
Fast
small footprint
cheap
I have no idea how drify a JFET can be...
I just know that generally all transistors change with temperature.
I might go to an op amp solution just to avoid all the textbook
reading..
D from BC
