JANA
I have measured the UV from a high voltage arch. The arc using wires puts
out far less UV than from using carbon rods for an example. The arch is
perfectly safe as long as someone does not touch it, or put anything
flammable in to it.
A number of years ago, I build a 4 foot high Tesla coil in the basement. I
used a 20 kV neon sign transformer as the power source.
JANA
_____
Wow, I hope nobody new building one read that! How about the UV frying
your eyes? Starting fires, blowing fuses, killing the dog, and ruining
your ears (if you have big caps on it)? There are a million ways high
voltage can destroy your family - although the most common way is for
you to spend all your time on it until the wifey divorces you. If it's
fun, it might kill you. This is the rule of life.
flammable in to it.
JANA
_____
bhauth said:The only issue with this type of project, is that it can be very
dangerous of touched while running.
