Issue with Single Phase to Single Phase Cyclo converter Circuit.
HI,
I am Hamid Nawaz and new at this forum.
I am trying to make a circuit for single phase to single-phase cyclo converter. Using Pic Micro Controller for Triggering Gate of Trails.
Triac -> BT151
Optocoupler -> MOC3021
For Trigring Triacs -> PIC Micro controller.
I was unable to find any circuit diagram with the Triac Driver part. After some experiments I found a method to trigger Triacs. The Problem When I try to Operate each bridge (Positive and Negative) separately both work fine but when I combine two Bridges in anti-parallel the fuse blows out.
I have checked much time, there is no shortage. Maybe I am not making the right circuit.
I am Using a 100 Watts Bulb at output and I don't have osciloscope available, I am not able to share output waveform. I have attached the circuit diagram of what I have made, I there is an issue with the circuit please suggest me the right circuit. Thanks
This is probably a timing issue. An oscilloscope would come in really handy to analyze this.
When you connect the two bridges anti-parallel, I assume that you inadvertently activate both legs of the bridge and thus create a short circuit between the supply rails which in turns will blow the fuse.
Note that a triac has two anodes, A1 and A2, not anode and cathode. And please do use standard schematic symbols, like so:
This will make it much easier for us to read your diagrams.
Sorry for sharing the non-technical Diagram. I am using an 11 ms delay between triggering bridges.
Moreover, I have added a resister between the Gate and Cathode of each Triac. Also added a snubber circuit with each trace but the problem is still the same.
