Can you use a zener diode and a cap on the base to turn a transistor all the way on really fast? Seem to me that this is a pretty simple bjt drive.
No
Sorry don't quite understand what you mean by this:
- The low output may be insufficient to turn off the transistor (and it is low when active). Can you use a PNP transistor between the +ve supply and the load instead of an NPN transistor in the ground lead of the load?
So you don't see any problems me using this up to 20v if I just remove or burn out the LEDs right?
As for the ambient light it isn't a problem, my circuit is in a box with a small hole on it, and the LED light that provides the light will be very close to the hole so mainly only light from the LED will be on my circuit.
... The PUT has the advantage over the UJT in that the place where Vp occurs can be adjusted using external components. It should be possible to use a PUT to do what you want, but I'm no expert in these devices. (Perhaps someone even older than me can help)
UJT's and PUT's are pretty rarely used these days.
If your interest includes microwave frequencies above 10 GHz or so, the Gunn diode or TED (transferred electron device) makes a robust oscillator when inserted in a tuned cavity. Radar speed guns use Gunn diodes and they have also been used by radio amateurs. Wikipedia has a nice article on Gunn diodes.
Sadly, except for a short tour in the USAF, and some propagation experiments at 70 GHz at the research institute, my practical microwave experience has been nil. Unless you can find surplus parts (waveguides, circulators, Magic-Ts, micrometer tuning stubs, horns, parabolic reflectors, etc.) and surplus test equipment, it is an expensive pursuit.
..............And hevans1944, you've been posting some great advice here! ........
Sorry by me trying to make this less confusing I may have made it more confusing.
My circuit is the LIGHTBOX, and the device my circuit/lightbox attaches to is a same circuit because 2 wires that come out of my circuit/lightbox (12v and 0V wires in the diagram above) go to this device I'm triggering. DEVICE is the thing I'm triggering with my circuit/lightbox.
So it goes like this. LED light lights up (forget where the LED light is coming from, I can't tap into that circuit for sure), that light goes into my circuit aka LIGHTBOX, which then needs to give power to the end product aka DEVICE vie the 0V wire which now should now have 12V because my transistor is ON.
PS I will try the schmitt trigger, I hope it fixes my problem. Removing my whole circuit and just making a short from 12v to 0v does the job, but I want that job done by light. Relay works great too but I want it done without having an external power source.
Yea I'm not sure exactly what is causing the problem in my circuit to be honest as this circuit is turning ON many different devices. Works on most, but not on some.
Here is a little background. My circuit (call it LIGHTBOX) is being used and attached to other electronic DEVICES, so it basically acts as a light relay and turns stuff ON/OFF on the device you put it on. My circuit above works on most devices but NOT on some. What I have noticed is that on the DEVICES that it does not work on, if you just short circuit the V+ to V0 on the device itself the device does the function that my LIGHTBOX should be doing in the first place. After talking to you guys I now suspect that the problem might be that some Devices I'm trying to turn ON aren't doing so because the signal from my circuit is slow on and might not even get fully turned on. I think schmitt trigger might be the fix for this so I'll try that first.
Is there a small/cheap schmitt trigger ic that I can easily integrate into my circuit?
