MRW
I am curious if it is okay to leave an opamp or comparator inverting
or non-inverting input open while the device is powered.
Thanks!
Thanks!
Op amps have such a high gain that leaving an input open will probably
drive the output into saturation, which isn't ideal. Better to
configure unused op amps as unity-gain (tie in- to out) and use a pair
of resistors to set the input voltage to half the supply voltage.
That keeps all the pins in spec and happy.
MRW said:I am curious if it is okay to leave an opamp or comparator inverting
Okay. I think I get it. Thanks! Hmm.. I do remember reading somewhere
that the opamp input terminal has to have a path back to ground to
make it happy.. or something like that. I don't quite remember, but I
guess that would make sense if we tie the inputs to a voltage source
or ground.
Would a circuit like this work?
GND
V
| GND
VIN2 -- ----|-\
| >-VO
VIN3-|+/
VCC
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
VIN3 in the diagram is a fixed voltage source, while VIN2 is either
there or not (like plugged in or plugged out). Thanks!
| GND |
| >-----+----VO
VIN3-|+/
VCC
or
vin2---+------1M------+
| GND |
| >-----+----VO
VIN3-|+/
VCC
Eeyore said:It probably won't damage it but it certainly won't work in any
meaningful way.
Graham
John said:probably >> drive the output into saturation, which isn't ideal.
Better to >> configure unused op amps as unity-gain (tie in- to out)
and use a pair >> of resistors to set the input voltage to half the
supply voltage. >> That keeps all the pins in spec and happy.
Some opamps will draw a lot of supply power if their outputs rail, as
they will if they are not operating closed-loop. And in some dual or
quad-section opamps, running one section open-loop will mess up other
sections. In general, keep all opamps running closed-loop, like this:
or some other way to keep it happy when your input is disconnected.
John
Thanks, John!
--- Hide quoted text -
- Show quoted text -
dear freinds,
there are many application notes to this effect from almost all big
manufacturers.
i think comparator pins can be left open, coz they are one way or the
other in saturation.
