IR "floodlight" using LEDs?
Don Bruder
OK, guys... you've all been having so much fun with LED flashlights, now
here's one for ya:
Show me some plans for a floodlight/spotlight (ideally, adjustable
between the two) *USING IR LEDs* that will light up a goodly section of
territory - Enough to make decent moonless-night video of deer with a
camera that has demonstrated itself to be QUITE nicely sensitive to the
IR wavelength used by all the remote controls I've got in the house.
Using several of the remotes together, I can get good detail out to a
few feet during testing in the makeshift darkroom of my bathroom. I can
clearly see and videotape my IR self in the mirror from about 5 feet
back using the remotes as the only light source. The picture fuzzes out
more the further back I get, with about 10 feet seeming to be the limit
of visibility. Only the remotes, merrily twinkling away, remain visible
beyond that point.
I'd like to improve on that concept. (not to mention make it more
convenient to handle than a fistful of remotes!) - Ideally, I'd like to
be able to "paint" a 20-30 foot wide area with enough IR to shoot video
with, at anywhere out to a couple hundred feet with decent image
quality. (Yes, I realize I'll never achieve color this way. I'd hope
*ANYONE* who'd consider a project like this would realize that, too! :) )
Any thoughts? Drawings? Magical inspiration? Suggestions on power
sources (Ideal unit would be hand-held, no cord. Corded to 12 volts of
DC (car battery clips or a cigarette lighter plug) would be acceptable.
AC powered need not apply, although I may eventually get around to
adapting one to AC if they work out nicely)? How about which LED is
likely to work best for this project?
Key here is "lighting them up" without scaring them off, like the
visible spotlight I've got does. Since I understand deer to be
UV-sensitive, but close to IR-blind (if not completely - jury still
seems to be deliberating on whether they can see it at all, or if
they're totally blind to it), I figure this would be the ideal solution
- Bathe 'em in IR light that they can't see, and then use a camera that
sees in IR nearly as well as it sees in daylight to catch 'em on tape.
R.Lewis
here's one for ya:
<snip>
Buy one or more of the many varieties of IR illuminators readily available
(manufactured specifically for the purpose you propose.)
John Popelish
here's one for ya:
beyond that point.
Don Bruder - [email protected] - New Email policy in effect as of Feb. 21, 2004.
I respond to Email as quick as humanly possible. If you Email me and get no
response, see <http://www.sonic.net/~dakidd/main/contact.html> Short
form: I'm trashing EVERYTHING that doesn't contain a password in the subject.
For large areas, if power is available, LEDs may not be the most
efficient. Brood lamps with IR filters may be cheaper and they put
out a lot of IR.
But if you want ot experiment with some LED arrays, get a bunch of
high power 850 to 880 nm (the 940 nm ones do not match the
sensitivity of most cameras as well) LEDS and build some arrays. To
keep them from getting hot, space the LEDS apart about a diameter or
so. You can series quite a few and run them off something like 48
volts DC with a single resistor to limit the current.
I like the LEDs from Vishay like this one:
http://www.vishay.com/docs/81091/81091.pdf
Since their forward current at rated 100 ma is about 1.5 volts, you
can connect something like 25 of them in series with a 120 ohm 2 watt
resistor and apply 48 volts DC. This will use almost .1 amp or 4.8
watts of power. But you will probably find that you need a half dozen
or more of these arrays to light the area you describe.
W
Watson A.Name - \Watt Sun, the Dark Remover\
here's one for ya:
beyond that point.
For the long distances, you will need some kind of reflector. And since
LEDs, even IR, put out a beam that's already somewhat concentrated, they
aren't amenable to being in a reflector. So the best way is to use a
regular incandescent lamp., which puts out tons of IR. All you have to
do is filter out the visible light and let the IR thru. You can get
much more IR that way, since the lamps are natural IR emitters.
subject.
buck rojerz
here's one for ya:
beyond that point.
You also may need to use manual focus on your camera. Depending upon how
the auto-focus works on your camera, auto-focus may not work.
IR illuminated objects focus at a differnt point than visible light
illuminated objects do.
If you are at a fixed distance from a given object and switch from
visible light to IR illumination, you will find that you may need to re-
adjust the focus on the camera.
cheers
buck
G
Gordon Youd
What size shells does your camera take???
Gordon.
here's one for ya:
beyond that point.
subject.
Don Bruder
It can chamber Hi-8, 8mm or VHS-C. I find it likes Maxell Hi-8 120s,
with the full plastic jacket, best. Less jamming when they're ejected. A
couple of years ago, I tried some Sony VHS-C 160s that I found on
clearance at Wal-Mart but those kept jamming, and left a lot (to the
tune of several feet) of tape residue wrapped around the record head
when I cycled the action. Something about those magnum loads just
doesn't agree with this camera, I guess, since I had the same problem
with the TDK 8mm 160s I tried a few months ago.
And as for your insinuation that this is going to be a poaching tool,
five words sum it up nicely: "You *GOTTA* be kidding, right???"
If I should decide I want venison on the table, I can poke my head out
the back door (or open the bedroom window, or step out on the deck, or
open the living room window, or... You get the picture? Deer are
*EVERYWHERE* around here) at nearly any time of the day, year 'round
except for maybe April and May (when all the does around here go into
hiding, presumably to do the "lets be a mommy" thing, and apparently,
take all the bucks with 'em in the process - they're just now starting
to show up, tiny little still-spotted fawns tottering along behind,
after their annual "disappearance" - they're about three weeks behind
schedule this year for some reason) and shoot as many deer as I have the
energy to dress out, without needing to resort to the time, expense, and
difficulty of creating/building/using what amounts to a "night-vision"
system to do it with. Never mind facing zero consequences for doing so.
(unless you count tolerating the flies that a gutpile from a
mass-slaughter like that would likely attract as a "consequence". But
seeing as I've also got horses (and the attendant flies), I'd likely not
notice that.)
It's a bit harder, though, to do night-filming, since once the sun goes
down, they *DO* get spooky about headlights, hand-held floodlights,
flashlights, and other visible light sources.
Sir Charles W. Shults III
Here is another very useful trick.
Use a light dimmer on a standard incandescent lamp, and turn it down to
the point where the lamp is just braaely lit. Now the output is almost
entirely IR and a pair of cheap filters can get you a very clean beam of it.
So use one of those directional spotlights such as a track light or reading
light and put a fairly high wattage bulb inside. Dim to barely glowing.
Cover with a piece of red plexiglass and a piece of blue plexiglass. The
results will be a very nice sharp spotlight of infrared light that is almost
completely invisible even if you stare right into the reflector.
Cheers!
Sir Charles W. Shults III, K. B. B.
Xenotech Research
321-206-1840
John Popelish
Cheers!
Xenotech Research
321-206-1840
If you put two lamps in series, so that they run at half voltage, you
don't need the dimmer.
If you use 250 watt brood lamps (reflector floods with red filters
painted on them) you only need to add the blue filter to get rid of
the visible.
I have a pair of brood lamps wired in series to hang over our bed for
when my wife's arthritis acts up in winter. They are dim enough they
we can sleep with them on. But I keep dreaming about developing
pictures.
If you has some of these running through sunset, I doubt that animals
would pay much attention to them with no further filtering. The Farm
Bureau and lots of hardware stores sell these for a few dollars each.
And at half voltage, they last a very long time.
Don Bruder
It CAN'T be that easy... Can it?!?!?!?
I'll definitely try it. Thanks!
John Miller
Please let us know how you get on.
I want to do the very same thing - deer, raccoons, possums, foxes, turkeys,
ground hogs. We get them all - right up to the back door (handing a raccoon
a slice of bread and having it take it with its "hands" is just one of the
pleasures).
On a vaguely related note, I have put a UV bulb in one of the outside
lights - attracts lots of interesting insects at night and you can get
fire-flies to signal en masse if you turn the UV light on and off at about
1Hz....
John.
subject.
G
Gordon Youd
Hi, Don, Points taken, no offence meant , I just could not let a joke slip
by.
In the UK we don't exactly have deer "outside our door".
I do like your in depth reply.
Kind regards, Gordon.
notice that.)
subject.
Don Klipstein
I have found that further adding green plexiglass to the red and blue
makes the output much less visible still. Haven't tried that with a lamp
dimmed to barely glowing however. But with a lamp dimmed that severely,
the infrared seen by most cameras will certainly suffer in comparison to
longer infrared wavelengths.
With red, green and blue plexiglass, the "visible" output is mostly from
nominally infrared wavelengths longer than about 730, maybe 740 nm or so.
With a high wattage incandescent at full blast, I suspect it will be dim
enough for animals to not notice. CAUTION - do not stare into the beam,
since your pupils may be more dilated than without the filters and you
might cook your retinas.
- Don Klipstein ([email protected])
Rich Grise
What about an ordinary heat lamp like you see on that platform between
the kitchen and the wait station at restaurants? They're _designed_ to
put out lots of IR!
For that matter, your wife's iron on "linen." ;-)
Cheers!
Rich
W
Watson A.Name \Watt Sun - the Dark Remover\
pleasures).
1Hz....
What kind of bulb is that? An uncoated Fluorescent lamp? I know that
the mercury UV lamps with a screw base like the ones they used in dryers
have to be on for a few minutes before they put out UV. They wouldn't
work if you turned them on and off at 1 Hz. Then there's the neon tube
UV lamp with the little beads of mercury inside the tube. It puts out a
nasty spectrum of UV with the short wavelengths that can badly 'sunburn'
you in ten minutes. I think I still have one of those old timers in the
garage.
Chris Hodges
garage.
I think it will be a fluorescent with a special coating (not the same
as a blacklight coating - they typically let more - bluish - vis
through than that).
Why do they need a few minutes to put out UV? If it's a temperature
(elctrode/plasma) issue then warming up before pulsing at 1Hz might
keep the temp high enough (especially in a reasonably enclosed
fitting).
Chris
John Miller
Actually, it's an incandescent one from the local grocery store - cost about
$5. GE Blacklite 60Watts. Barcode 43168 22767. It's a standard bulb
coated in a UV transmitting/vis blocking material.
John.
Don Klipstein
The drier lamps put out shortwave UV (2537 nm and 184.9 nm) and not much
longwave, and won't be that useful for attracting insects. These are now
collectors' items. They put out a fair amount of UV before they warm up -
not that much different from fluorescent lamps in warmup requirements.
garage.
I used to have one - puts out 253.7 nm and not much UV of any other
wavelength. I once (25 years ago) saw one in a thrift shop, and it was
supposedly a sunlamp. The 253.7 nm wavelength is used for germicidal
lamps.
Then there are the high pressure mercury vapor sunlamps - the RS
("reflector sunlamp" floodlight with a medium screw base or the RSM
version with the mogul screw base), and some models, mainly by Sperti
with bare arc tubes and heating elements as resistive ballasts. These put
out plenty of 365 nm (not much effect on human skin) and 313 nm (UVB), and
a lesser amount of wavelengths that were shorter but in the UVB range.
The mercury vapor pressure in the arc tube when fully warmed up was
close to atmospheric pressure, but according to "The High Pressure Mercury
Vapor Discharge" by W. Elenbaas these fit the description of high pressure
mercury vapor lamps.
buck rojerz
[email protected] (Don Klipstein) wrote in
much
now collectors' items. They put out a fair amount of UV before they
warm up - not that much different from fluorescent lamps in warmup
requirements.
was supposedly a sunlamp. The 253.7 nm wavelength is used for
germicidal lamps.
put out plenty of 365 nm (not much effect on human skin) and 313 nm
(UVB), and a lesser amount of wavelengths that were shorter but in the
UVB range.
Mercury Vapor Discharge" by W. Elenbaas these fit the description of
high pressure mercury vapor lamps.
I actually have one of those "dryer" lamps as you refer to them, except
mine is in a hand-held mineral light. It has a filter in front of it to
block out most of the visible light. By todays standards it isn't a very
bright black light. I have some B.L. leds that are much brighter than
the mineral light is. The mineral light has a small ballast on a line
cord going to the hand-held part, that encases the bulb. It still works
just fine. When you take the filter off, you quickly notice that the
bulb is also an ozone producer, as well. But I don't stare at it that
way... bad news, for sure. It looks just like the un-coated flourecsent
tubes. (I know, I said I didn't look at it.) ;)
cheers
buck
cheers
buck
A bit like the sign on the laser cutter "do not look into laser with
your remaining good eye"
