John Larkin
I wonder how I might calibrate such a homebrew current transformer?
1 ohm divided by 100 gives 10 mV/amp.
Shouldn't I see some serious ringing in the current waveform if my shunt is that inductive?
No. Typically the error results in a current step having a substantial
overshoot on the leading edge of the sensed voltage, with a
complex-exponential decay tau more or less in the few hundred
microsecond range. The complex decay is an infinite sum of
exponentials as the magnetic fields soak into the shunt matarial,
eddy-current wise. It's one of those ugly diffusion things. It's hard
to make shunts or heatsunk power/wirewound resistors that have clean
transient response. Vishay makes some super-precise metal foil power
resistors, 4-wire in a TO-3 can, that have 100% overshoot on a current
step, decay in the 500 usec range. I was impressed; then I started
making my own shunts.
If you tuck the sense wires in close to the shunt intill they meet in
the middle, and then bring them out as a twisted pair, that minimizes
the effect, but most shunt geometries limit the improvement. There's
also the common-mode/ground-loop issue.
John
