Dan Charette
Hi All!
I've got a small toggle circuit that I'm using to drive a shutdown
circuit on an audio power amplifier. The circuit is made from a
CD4093 Schmitt trigger NAND configured as a debouncer for my mute
switch input. The output of the 4093 is fed into a CD4013 fo provide
toggling cabability. I've got S and R tied directly to ground. But,
I'd like to explore the possiblity of providing a predictable power-up
scenario. Currently, the circuit upon power up will default to one
state or the other. What are some methods that you fellas have used
to achieve a known state consistantly with a flip-flop like this when
the power supply is from a single source. First gut instinct that I'm
thinking is to make some sorta RC timing circuit on the power supply
pin so that I can provide the set or reset pins with something known
before the power supply pin comes up. Any thoughts? Also, I don't
want to add too much additional circuitry... if I can solve this
purely with passive components or a few transistors, that'd be great.
Thanks!
Thanks!
