Hi Audioguru- I am not sure I understood. Do I use my multimeter to make the measurements, while the circuit IS connected to the power supply at 9V.
or
Do I use my multimeter to make the measurements, while the circuit IS NOT connected to the power supply ? I am thinking it should be connected, otherwise, I would not get any measurements.
To be clear, this is the way I did it. I hooked up the + and - rails to the + and - of the power supply that fed a 9volt supply.
Then I put the black lead from my multimeter, on the negative terminal of the circuit, and moved my positive test lead, to the points in the circuit you suggested I measure. Did I do that right? Maybe I am getting confused with the term "load". I interpret that to mean, voltage being supplied to the circuit.
