Idea for a Vector Network Analyzer
Adam S
I had the following idea for a home built vector network analyzer project.
The block diagram is shown below. Essentially channels A and B are mixed
down to separate 1kHz IF and sampled with a stereo 24bit DACE for the
PC. Phase and magnitude of the resulting 1kHz signals are then
calculated with DSP methods.
f1-f0 = 1kHz as f0 sweeps from 0 to 20MHz.
I know there will be problems as f0 gets close to 1kHz and again at near
0Hz, due to SA602 not being an ideal mixer.
Anyone think concept won't work ?
To PC
------ |FT245BM|
ch A ----- | | | |
o----|SA602|---| 2kHz |------. |USB I/O|
|mixer| | LPF | | -------
| LO | |
o----. |24bit | | AVR |
| | | ADC |---| |
| | |stereo| | uC |
ch B ----- | | | | |
o----|SA602|-----| 2kHz |----' |
|mixer| | | LPF | |
f1| | | |AD9834| |
'--| 20MHz|---| DDS |-----o
| LPF | | | |
SIG / | f0| | |AD9834| |
OUT__/ |--------| 20MHz|----| DDS |----'
f0 \ | | LPF | | |
BUFFER
[view in monospaced characters]
allanherriman@hotmail.com
To PC
------ |FT245BM|
ch A ----- | | | |
| LO | |
| | | ADC |---| |
| | |stereo| | uC |
|mixer| | | LPF | |
f1| | | |AD9834| |
| LPF | | | |
f0 \ | | LPF | | |
BUFFER
Yes, it won't work. You are mixing down to DC, and you have lost the
ability to sense phase. For example, if you read an amplitude of 0 on
'B', you don't know whether this is due to a large attenuation between
Sig Out and B, or whether it's due to a 90 degree phase shift between
Sig Out and B.
Try a quadrature downconverter:
.. To PC
.. ------ |FT245BM|
.. ch A ----- | | | |
.. o-+--|SA602|---| 2kHz |------. |USB I/O|
.. | |mixer| | LPF | | -------
.. | | LO | |
.. | '----. |24bit | | AVR |
.. | | | ADC |---| |
.. | | |stereo| | uC |
.. '--|SA602|-----| 2kHz |----' |
.. |mixer| | | LPF | |
.. | f1| | | |Quad. | |
.. | '--| 20MHz|---| DDS |-----o
.. | SIN | LPF | | | |
.. '-------| 20MHz|-----'
.. COS | LPF |
You will need one of these for chan A, one for chan B. You can get by
with one if you only want to do 'through' measurements.
I recommend using a single DDS for both stimulus generation and
downconversion LO. This avoids problems with phase shifts between the
two DDSs in your first solution.
Allan
allanherri...@hotmail.com said:
Adam S wrote:
Maybe I should read your post more closely before I comment next
time...
Your use of a frequency offset does indeed allow you to sense phase
differences between A and B.
Allan
Adam S
time...
wheew, I spend quite a while with pencil and paper playing around with
trigonometry identities trying to see if phase and magnitudes of the two
IFs do indeed represent that of inputs A and B.
Adam
Chris Jones
To PC
------ |FT245BM|
ch A ----- | | | |
| LO | |
| | | ADC |---| |
| | |stereo| | uC |
|mixer| | | LPF | |
f1| | | |AD9834| |
| LPF | | | |
f0 \ | | LPF | | |
BUFFER
Are you already aware of the N2PK network analyser? (Try google). I think
your idea of using an IF frequency rather than mixing down to DC might be
preferable but there probably isn't much difference. Using a non-DC IF,
you might be able to make the receiver digitally filter out responses due
to the third (and other) harmonics of the source frequency, which could
make the signal source purity less difficult. The third and fifth
harmonics will unavoidably be present in the receive LO (since the mixer
only works well with hard driven LO port, creating odd harmonics), but
since the source and LO frequencies are different by 1* fIF in your system,
the harmonics of the source will be received and downconverted to
frequencies 3fIF and 5fIf etc. which are not the same as the desired IF
signal so you can filter them out.
I would also like to make a VNA, but to be interesting to me I would really
want it to cover the 2.4GHz WLAN frequencies so I could test filters,
antennas etc. The receiver part looks feasible to me using AD8343 mixers,
or maybe diode samplers, but the signal source and the s-parameter test set
seem like the challenging parts to me. Rather than a 10kHz to 3GHz signal
generator, I wonder is it easier to generate a very wideband pseudo-random
bit sequence using ECL type comparators or latches, and to use that as the
stimulus, recording the response of the network in the time domain using a
second shifted PRBS generator driving a correlator, and computing the
frequency response. I fear that this would take too long for a very wide
sweep however.
Chris
Adam S
To PC
------ |FT245BM|
ch A ----- | | | |
| LO | |
| | | ADC |---| |
| | |stereo| | uC |
|mixer| | | LPF | |
f1| | | |AD9834| |
| LPF | | | |
f0 \ | | LPF | | |
BUFFER
sweep however.
Chris
That last part paragraph flew over my head. I've heard of PRBS
generators used as a stimulus for audio speaker frequency analysis.
Maybe there is someway of correlating two of these generators and use
digital sampling (ones and zeros) at super high speeds to somehow
compute the frequency response. Could just be my imagination.
I have seen the renowned N2PK network analyzer published on the web. I
would of though dynamic range could be seriously improved by using AC,
as DC would have drift problems. Once the 1kHz is inside the PC then
there are no noise/drift sources to speak of. There is also the other
advance as you mentioned, about harmonics of the source signal being
blocked by the 1kHz since they will not be 1kHz relative to harmonics of
the LO. But the catch is the DDS generates a bunch of non-harmonic
related spurs that shift all over the place as you sweep the frequency.
At some frequencies multiple harmonics will get mixed down to 1kHz and
cause error on the output. The DC mixing method of the N2PK will have
every spur joining together from each DDS and mixing down. Some will
subtract some will add. Needs more thinking..
Adam
Chris Jones
Adam said:
Chris said:
project. The block diagram is shown below. Essentially channels A and B
are mixed down to separate 1kHz IF and sampled with a stereo 24bit DACE
for the PC. Phase and magnitude of the resulting 1kHz signals are then
To PC
------ |FT245BM|
ch A ----- | | | |
| LO | |
| | | ADC |---| |
| | |stereo| | uC |
|mixer| | | LPF | |
f1| | | |AD9834| |
| LPF | | | |
f0 \ | | LPF | | |
BUFFER
think your idea of using an IF frequency rather than mixing down to DC
might be
system, the harmonics of the source will be received and downconverted to
really want it to cover the 2.4GHz WLAN frequencies so I could test
filters,
mixers, or maybe diode samplers, but the signal source and the
signal generator, I wonder is it easier to generate a very wideband
pseudo-random bit sequence using ECL type comparators or latches, and to
use that as the stimulus, recording the response of the network in the
time domain using a second shifted PRBS generator driving a correlator,
and computing the
sweep however.
Chris
I think that the N2PK design would not have bad DC offset problems because I
think he flips the phase of the LO and then subtracts the two readings,
thus getting rid of any offsets in the mixer and LO leakage into the
receiver input. In some ways this is equivalent to having a very low
frequency offset between the LO and source, the frequency offset being
equal to one half cycle as often as the PC feels like it. It's probably
not quite as good as a proper offset between the two frequencies though.
Adam
With regard to the DDS spurs, I think that the ultimate answer is to have a
different kind of synth which I want anyway because I want coverage up to
2.5GHz at least. If that is too much work, then a big improvement could be
had by moving from the AD9851 to the AD9951, which I think has more DAC
resolution and much better spurs (and is more than twice as fast too).
Chris
