Hi everyone.
I'm trying to fix a Bell 5005 Stereo PA amplifier. It has a rotating ON switch at the front which seems to be causing the circuit breaker in my garage to trip every so often. I opened it up and the contacts looks a bit blackened so I cleaned them up (with 99% isopropanol + scraping with a screwdriver). It certainly help but after a few more tests at turning it off and on again it trip the breaker again. I've made a video. Here is the link...
Ideally I would like to be able to retain the existing switch but I'm not sure exactly why it is tripping the breaker. I have been looking into replacing it but there is no such part anymore and the cut out in the front panel is only 9mm diameter and I can't seem to find anything that will fit. Also as I show in the video the ON switch connects both the live and neutral to the primary windings of the transformer at the same time. Is this necessary or could I just permanent wire the neutral and then find a switch that just makes one connect on the live side. This is how my guitar amp is wired. Is there any reason why the Bell PA needs both sides connecting on the switch?
