I have dji mavic pro gimbal and camera help me wiring it so that i could use it as separate camera
Hi, do you want to remove the camera from the gimball?
It depends whether the cameras supporting electronics is in the housing or integrated with the gimbal electronics.
Check how many wires are coming from the camera. Generally, 3 wires are power and video, 4 wires are power, video and audio. I assume the camera housing doesn't pan and tilt, the gimbal does this?.
Martin
No i dont want to remove the canera i want to use it all as gimbal and camera . Is therr any kind of board which connects to this pins ?
I dare say they are proprietary and only DJI use them.
You could count the pins and measure the pin spacings along with the connector dimensions. That may give you a start for an internet search.
But I'd probably find a dedicated forum for drones where people hack and pull them a part.
Other members here on EP May have better answers for you.
Martin
I must say though, they do look very similar to iPhone 5 connectors. Obviously not.
Have you got the drone?, you could possibly trace the important connections. Leaving all ancillary connections out.
Martin
