Spehro Pefhany said:
Hmm. Well, let's us take those units out of the particular problem
domain they were designed for and try to figure out how many watts
it takes to maintain temperature difference of 10C (18F) across a
0.5" (12.7mm) piece of P20 steel 3/8" (9.52mm) thick. Convert
between W and BTU, between in or mm and square feet etc. Lots of
unnecessary work and possible places for errors.
Hello Speff,
You can eliminate most of the work and errors by using an equation
solver. Just enter the unit conversions, then solve for the desired
parameter.
This method is very fast and gives high confidence in the accuracy
of the results. I have tried different equations solvers but found
Roger Schafly's Mercury to be the best for this work.
Here's a simple example. Say we need to find out how many
barleycorns there are in pi furlongs.
Start by entering the unit conversions. (Note there is no direct
conversion between barleycorn and furlong.)
; Unit Conversion Factors
foot = yard * 3
furlong = yard / 202
inch = barleycorn / 3
inch = foot * 12
yard = fathom * 2
Now enter the desired parameter(s):
; Parameters
furlong = pi
The solution is:
barleycorn = 68536.985330715
fathom = 317.300858012569
foot = 1903.8051480754
furlong = 3.14159265358979
inch = 22845.6617769050
yard = 634.601716025138
(I simplified the printout to make it more readable.)
Now you can solve for any unknown. Just enter the desired parameter
and press solve. Unlike ordinary algebra solvers, you don't have to
rearrange the equation to put the unknown on the left side. This is
where many of the errors occur.
Once you have entered the necessary unit conversions, you don't have
to touch them again. This saves time and eliminates errors, since
you are re-using conversions that have already been debugged. You
can simply cut and paste from other files to add more units whenever
needed. Pretty soon you will have a library of conversions you can
draw on that will simplify and speed your work.
Roger Schafly's Mercury is free and available at
http://www.mindspring.com/~schlafly/eureka.htm
Hope this helps.
Regards,
Mike Monett
Antiviral, Antibacterial Silver Solution:
http://silversol.freewebpage.org/index.htm
SPICE Analysis of Crystal Oscillators:
http://silversol.freewebpage.org/spice/xtal/clapp.htm
Noise-Rejecting Wideband Sampler:
http://www3.sympatico.ca/add.automation/sampler/intro.htm
