How to use 10ms delay for clock signal ( 3MHz ) using hardware
Hi All,
We need delay circuit ( 10ms ) for clock signal ( 3MHz ) using any hardware circuit using less number of components.
A 3 MHz clock delayed by 10 ms is still a 3 MHz clock and will be undistinguishable from the original clock.
less than what?
This description is too vague. Please give us more specific details what you want to achieve.
less than what?
thanks for your reply. We using audio clock generated from audio processor using IOMUX - GPIO pins and we found,
LRCLK is 48 KHz
BCLK is 3.072 MHz
and which is connected to some other peripherals. But in the peripherals datasheet, word sync to the same should be given 10ms after the bitclock is enabled. So need to provide the delay for 10ms from Processor output.
Please reply and let me know any clarifications.
