Yzordderex said:
Gonna have to agree with Mr. Bloggs here.
Did you read what I told you about the 90amp scr doing 7000amps? I
would imagine you can buy a little TO-220 scr or one of those cute
little stud mounted jobs that would do fine. Probably no heatsink. A
25amp device should be plenty.
While searching for suitable SCR's, I didn't see any that would handle
pulses of 70-80 times their continuous rating!
20 times is more typical. For example, the existing unit uses a
ST230508POV rated at 230A continuous and 5970A non-repetivive. Sure,
it's overkill, and the hockey-puck (DCR604-14) even more so, but the
puck was cheaper. There's no way I would try a TO-220 for this job.
Your 350ma at 3.5v of gate drive might
be just the right amount to smoke a big hockey puck. The Key here is
to smack the gate with a nice big pulse of current in a hurry. A
little MLC discharge into gate would be a nice choice here.
You may be right there, 3.5v is a touch high, make that 2.8v. The DCR604
has gate ratings of Igt=150mA and Vgt=3v. I'll be pulsing a pnp
transistor to switch +24v to the gate via a 68R resistor with a string
of diodes to clamp the gate to 2.8v.
And yes, the scrs will be cheaper than a big relay. And the relay
will wear out while the scrs will keep on ticking.
The guys I'm doing this for were happy to spring for the relay
(contactors), so the price was very good!
We deferred to the advice of NHP's technical people, who specified two
32A four pole contacters (two poles paralleled on each) with a
mechanical interlock that allows only one to operate at a time. They
said the current was no problem, except that it could cause the contacts
to lift and arc due to the magnetic field around them. Their solution
was a latch that fits to the top of each contactor, locking it down when
it activates. A pulse to the latch later releases the contactor. More
complex than I'd like, but it's just four coil simple driver circuits
with some caps to fire pulses to the latch drivers.
Rob Storey
