Rob Storey
(my first post to this group)
I have a magnetizer project that needs to discharge 3x4700uF at 300V
into a coil via an SCR, resulting in a current of around 2000A for about
5ms. The complication is that the direction of current through the coil
needs to be selectable, which implies the use of a DPDT style relay.
Arcing is not a problem here, as the relay will never switch while
discharge is in progress, nor when voltage is present. The prime issue
is the very short term current carrying capacity of the closed contacts.
My problem is selecting a relay with adequate contact ratings for this
job. Relay specs typically only give ratings for continuous AC and DC,
and for various load types (resistive, inductive). The ratings also
appear to be specified for conditions where voltage is present on make,
and current is flowing on break.
Where I have found some short term current figures (minutes and
seconds), extrapolation down to 5ms leads me to conclude that a
contactor rated at 50A or above would handle the job. But these cost
hundreds of dollars, and being triple-pole/single throw, I would need
two of them, and also need to ensure only one is active at a time.
The unit I'm building is to replace an existing system (where the
reversal is done via a large manual switch), and in that unit the wiring
used to carry this large current appears to be nothing special, just 20A
automotive type wire.
So if that wire doesn't turn into a strip of smoke, surely I can get by
with a modest relay costing $50-$100?
Can anyone suggest a type of relay that would be adequate for this
project?
Also, since there would never be any current flow during switching,
would contact maintenance be an issue?
Any help or suggestions will be greatly appreciated.
Thanks in advance,
Rob Storey
project?
Thanks in advance,
Rob Storey
