I ordered these single coil latching relays and didn't get a schematic
with them and.... I'm lost as to how to hook them up. Any info would be
appreciated... whitefoots
you need some sort of reversing switch or H-bridge so similar setup that's
able to drive the coil in both directions,
one way turns the relay on the other turns it off.
Here are two ways you couild do it using ordinary switches
ascii-art: use a fixed-pitch font (eg:courier):
windows users paste into notepad.
google groupies select "view original" under options.
push-button latchin relay drive
| "on" "off" |
----------+--o _____ o--'
_-o---[~-_]---o-_
----------+--o-~ ~~~~~ ~-o--.
| relay coil |
here it's done with two momentary SPDT switches
(you could use microswitches)
switch follower latching relay drive
+ ----o +||
_-0----||------------...---------------------.
- --+-0-~ || 1000uF |
| long wires |
| _____ |
`-------------------------...--------------[~-_]--'
relay coil
here it's done using a capacitor and an ordinary spdt switch
you could use a small battery for a power source,
it'd last years.
