I copied the drawing below, for reference. The
current through Q3 (which is equal to Q4 and is
half the bias current), goes through Q1 and sets
its Vbe voltage. Q2's base is tied to Q1's so,
assuming they have equal current, Q2's emitter
voltage has to equal Q1's emitter voltage. Once
we know that we can start evaluating the currents,
to see what they do. Q2's collector is especially
interesting because if Q1 and Q2 don't have the
same current, as programmed by Q3 and Q4, then
Q5's base changes to control the current Q5
takes from R1, and bring Q1 and Q2 in balance.
. +250V Rs 10.0 Iout
. IN ----+---/\/\----+------o ---> 0 to 10mA load
. R1 R2
. 100 190 all resistors 1%
. | | R1 = 10Rs
. ,-------+ | R2 = 2R1 - Rs
. | e e
. | Q1 b --+-- b Q2 Q1 Q2 matched pnp
. | c | c pnp Q3 Q4 matched npn
. | | | | low-voltagehigh-gain
. e +-----' |
. b --- | ----------+
. c Q5 +-----, |
. | mps | | |
. | A92 c Q3 | c Q4
. | b --+-- b npn
. | e e
. | R3 R4 10k 1%
. | |___________|
. \ Ib/2 | 270k 4.99k
. / Ib '--/\/\---+--/\/\--- gnd
. \ 100k 0.5W |
. | 0.5W 5% \ 4.99k
. | 4.99k \
. | ,--/\/\---, | 4.99k
. | | __ | +--/\/\---, 0 to +5V
. '---+--|- \ | 4.99k | __ | out, for
. | >--+---/\/\--+--|- \ | 0 to 10mA
. gnd ---|+_/ | >--+----
. gnd ---|+_/
OK, I'm curious too. I'll run a spice model.
Could you send me the spice file? (or post it here - but not on ABSE
as I don't have access) I'd love to play around with it: viewing
circuits in spice really helps me to understand them.
No. I don't think you're allowed to let the APD
voltage change much, once you've found the magic
value. I allowed 100mV fs, which might be too
much.
Well, the current gain of the APD decreases as you decrease the
voltage across it. Take for example:
http://sales.hamamatsu.com/assets/applications/SSD/Characteristics_and_use_of_SI_APD.pdf
- figure 2-4 and 2-5 show gain vs. voltage. I guess at the higher
reverse voltages (where I will probably be running it) the gain is
quite sensitive to changes in that voltage. Then again, the main thing
I'm looking for is just an on/off pulse, so it's not the end of the
world if the gain fluctuates some. Just how much gain fluctuation is
allowable is just impossible to estimate at this point, though.
You could use a transimpedance amplifier,
sitting at 250V, but what you really want is a
Tektronix CT-1 AC Current Probe, like this one,
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190175118289
You just run the wire through the little hole in
the 3rd photo, and you're all set! Measure away,
with your 2GHz 50-ohm scope! Ahem!
Ah phooie - here all I have is a 60GHz scope. Err, hmmmm... make that
MHz. My trusty old Tek 2215A, to be exact
So - allow me to go into my plan in a bit more detail: My plan is to
power everything off of a single 5V supply. The analog supply
(probably +-12V) will be generated with normal boost and inverting DC/
DC converters. The 250V supply will be generated with a non-isolated
flyback supply. It'll be held at something like 25V above the APD
supply. An op-amp driving a couple FETs will actively regulate the
voltage across the APD, with the idea of eliminating, or at least
reducing, the noise from the flyback supply. In theory, that could
keep the voltage across the APD at a constant, no matter what current
was flowing. In reality, of course, I'm not sure if it's possible to
get the bandwidth of that circuit high enough. The design I'm working
on looks alot like Figure 6.47 "High-voltage regulated supply" from
AOE, but I'm seeing bandwidth in possibly the single digit MHz region
at best. It still needs alot of work to be sure - I'm still at a
pretty early stage on it.
So the Tek current probe is just a current transformer, right? Are
there plain current transformers on the market with similar
performance? I'm aiming to keep parts cost for this entire project at
around the cost of a single one of those guys (~$500 new), as I'd like
to make a bunch of them. Also, what would the output of such a circuit
look like when looking at the current through my APD? I had thought
that current transformers were more for periodic signals, while the
signals through the APD will not be periodic.
To me what might make sense is to float a high speed instrumentation
amplifier with a ground at say 250-10V using a zener. Use that to
watch the voltage across a very small shunt, one that might produce
50mV or so at peak current. I don't believe a drop that small will
affect the APD in any significant manner. Run the output of the
instrumentation amp into an op-amp acting as a transconductance amp
that puts the current into say a current buffer like what you've done
with the MPSA92, then take that current and run it through a
transimpedance amp to generate a voltage.
Does that make sense at all? That's alot of black boxes, which always
scares me... Also, it seems most instrumentation amplifiers top out in
the single or double digit MHz region, which probably isn't enough.
The reason I wanted current sensing to be high side was so that I
could use the APD side of the shunt resistor as the feedback for my
high voltage regulator circuit. But if I could use a small enough
shunt, I think it'd be just fine for it to be low side, which would
make things easier I would think as I could just use a non-inverting
amplifier to get the voltage up to something reasonable. Maybe that
would be a more reasonable path to take?
I'm going to cut myself off now before my post becomes novel length.
Hopefully it isn't all completely insane.
Thanks!
-Michael
