Michael
Hi - I want to put a high side shunt resistor on a grounded load
(~10ma peak) that has about 250VDC across it. I then want to have a
ground referenced voltage that is the amplified difference across the
shunt with a range of about 0-5V. I would like the voltage across the
shunt to be in the low mV range. Power supplies available to me will
be the 250V, which will be noisy, 5V, and probably some sort of +-12V
analog (clean) supply. I would like to get 8b or more of resolution
from the ground referenced amplified shunt voltage signal. I would
also like this circuit to be fast. The faster the better, MHz
bandwidth at least. If this were a lower voltage I'd just do an op-amp
difference amplifier. Unfortunately, last I checked, Apex had the
market for op-amps that can handle such high voltages fairly well
cornered, and their op-amps are expensive, large, and not particularly
quick. High side current amplifiers seem to top out at about 100VDC.
So I'm trying out various ideas. My favorite right now is to put
voltage dividers on both sides of the shunt to drop the voltage down
maybe to 0-10V on both and then use an instrumentation amplifier to
amplify that voltage. For some odd reason this bothers me, but I can't
place my finger on just why.
Am I being paranoid and the instrumentation amp is a legitimate idea,
or is there a better way to do this?
Thanks!
-Michael
Thanks!
-Michael
