Jack said:
I have already tested cold fusion cells, especially H2 cells
and now wait for delivery of ethanol/methanol fuel cell membranes for
testing purposes.
They exist and work a lot better than cold fusion
There is no fuel in my 6-layer wafer.
The only fuel is heat from sunshine and rain water to power water fuel
cell, once on the market.
You seem to be sure that the water fuel cell is a viable option but have
given no evidence to show that. I did ask if it was Meyer's water fuel cell
but had no answer. -then what is it?
Peltier is to transform heat energy into electrical energy and to cool
solar cell.
If it is used to transform heat energy to electrical energy then it is using
waste heat from the solar cell. Will this cool it? If it does then the
Peltier output decreases and the cooling effect decreases. If you intend to
use the Peltier to cool the solar cell (why?) then you will need an energy
source to accomplish this.
Both Piezo and Electret are intended to use energy of sea
fine- but have you looked at the characteristics (particularly voltage
levels and power output levels) of these and the energy conversion
efficiencies?
How these various thing behave is something that you should know.
Now you have a device sitting in the sun, and getting further input from the
sea and wind and somehow adding on bits and pieces that, as far as I can
see, are actually energy sinks
I have already got very small size generator powered by wind energy.
but your comments are irrelevant
They are damned relevant. Maybe that is why you don't want to face them.
-------------,excellence or feasibility. I can claim that pigs can fly but backing it up
is a problem.
exactly, still under development
Or, you are whistling in the wind.
and have avoided questions regarding the
what questions abut ?
Peltier ?
Piezo ?
solar cell ?
so far so good
-?????- got one that works?
Electret ? OK
very small wind energy powered generators ?
Now put together as you propose - you may end up with the good sources
producing energy which is absorbed by the rest of the setup resulting in
less output than would be available from the solar and wind sources
separately.
You get your questions already answered on the net.
Go to Google and ask your question.
What source -Keelynet? You are still avoiding the issue. There are good
sources on the net but for every one of these there are sources which are,
put basically, pure bullshit. Got any references? Can you separate the real
from the imagined?
What you say for some components is fine- for others it is nonsense
concept is great and excellent
I have already got 2 companies interested to support me with funding and
materials supply .
water fuel cell is still under development
let us see what we get in few next months
Any references re water fuel cell? Any physical backing for this?
--> overall energy conversion
You are right - there is not even that.
6-layer wafer floating on the sea as life saving equipment.
In the meantime got concept of 7th layer from another company.
Can
sunshine, heat energy is transformed by solar cell, Peltier into
electrical energy
sea wave energy is transferred by Piezo/Electret into electrical
energy, water fuel cell generates electrical energy
small wind energy powered generators supply electrical energy
7th layer still under development
You apparently are
not exactly
energy comes from 5 sources and is transformed into electrical energy
No- I am thinking of what happens in the whole package and wanting to know
what the energy flows and balances are. You havenot provided any information
regarding this and your concept has shifted around from heat pump/engine to
a mix of other ideas without any reasoning. At one time you were getting
electric energy from osmosis but also indcated that osmosis doesn't need
energy input. Shades of perpetual motion.
Solar, sea, wind and if you have your 7th element- chemical. The rest ???
in the night work Piezo/Electret layers or wind energy layer as option,
water fuel cell layer as option
7th layer chemical fuel cell is on only for a short time
you are wrong
each layer works independently, generating electrical energy given
conditions are met
Good - now we are getting to a number of different known devices working
independently in layers(?) We have those. Relative power output of the
propsed mechanisms??? Where is the invention here?
Independent sources feeding to a common load - fine- This is not new -but,
until now you have not indicated or implied such independence. Remember that
you started with an impossible heat pump/engine scheme and now are throwing
in a whole mixture of ideas without due consideration of the interactions
(or lack of). My following comment still holds.
That is a non-answer.
is Peltier something wrong to you ?
is Piezo ?
is solar cell ?
is sea wave energy ?
Those exist -I do not deny that..
problem here- where's the evidence that it actually exists? Sounded good but
it appears to be a dud.
is wind energy ?
is chemical fuel cell ?
These exist but you forgot your amazing water fuel cell which is also a
non-starter.
The problem is that you are trying to layer things that work with things
that don't and have simply ignored any analysis of what the end result will
be. Don't you think that some form of analysis and backing up of such
analysis with solid data or theory might be useful? Simply because some of
the things that you promote are feasible, doesn't mean the combination is
feasible (particularly when you throw in cold fusion and water fuel cells).
Possibly many years being exposed to a scientific and engineering education
and practice and the associated need to defend ideas against criticism
(compared to which, my criticism of your ideas is really quite gentle) may
have something to do with it. It is also a desire to see some meat rather
than wishful thinking. If you know what you are about then you should be
able to answer my questions/criticism with solid analysis/data. So far, you
haven't tried.
Anyway, I am going to build 10-layer renewable energy life-saving
floating wafer.
goodness me - first it was 5 then 6 then 7 and now 10.
Go ahead. Have fun.
If you succeed, I'll eat crow. Boiled.
I won't heat the water yet if you don't mind.
