How solder to very fine enamelled woven wires in earphone lead?
W
Will
I have some Sony in-ear headphones. The lead to one earpiece has
been cut through completely and I want to rejoin the two wires
(which I will call 'conductors' to avoid confusion).
The two 'conductors' inside the lead are rather thin. And what is
more, each of the two 'conductors' is made up of something like a
dozen smaller copper wires which are woven around some very fine
threads (perhaps the threads are very fine polyester yarn). The
threads run along the lead as the core of the 'conductor'.
The wires of one of these two 'conductors' looks like bare copper
and is unoxidised so I can probably solder to it. But the OTHER
CONDUCTOR is the PROBLEM because its fine wires are enamelled.
How can I remove this enamel coating in order to be able to solder
to the fine copper wires of the 'conductor'?
Below is what I have tried.
Can you advise?
Will
Maybe my general technique is not delicate enough or maybe I am
being too clumsy but this is what I have tried with no success:
(1) Using fine glasspaper but it seems to tear the fine wires
rather than strip their enamel away. Even if the wires don't
break, there is still a portion of uncleaned enamel of the inner
sides of the fine wires.
(2) Using a match to burn off the enamel but this leaves a black
deposit which I have to scrape away with glasspaper and I am back
to the beginning.
(3) Using a gas flame always seems too fierce as it burns through
the wires.
----------------- END -----------------------------
Boris Mohar
Both wires are covered with different color enamel. You can likely apply
solder directly to the wires and the heat will burn off the enamel while the
flux does its job. Some enamels are designed that way.
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
Palindr☻me
Can you advise?
Will
to the beginning.
the wires.
As another poster has suggested, the heat of a soldering tip
may do the job - indeed some fine wire enamels are designed
to convert to a soldering flux on the application of a hot
iron. Dipping the end of the wire in a solder pot for a few
seconds should od the job too.
If you cannot apply heat, then nail varnish remover can work
very well. It may wick up the strands though. Applying a
drop of candle wax first and stripping and trimming back to
the wax should work.
If you don't have nail varnish remover, then I guess paint
stripper may do the job..but nail varnish comes with a handy
applicator brush.
Another thing that can work is a gas blowtorch with a
catalytic converter nozzle that turns it into a tiny hot air
gun. Loads enough temperature to remove insulation (or
heat-shrink tiny sleeves or in a confined space).
Dave Plowman (News)
apply solder directly to the wires and the heat will burn off the
enamel while the flux does its job. Some enamels are designed that way.
They might be. However, the standard way is to burn them off with
something like a cigarette lighter.
K
Ken Weitzel
Palindr?me said:
As another poster has suggested, the heat of a soldering tip may do the
job - indeed some fine wire enamels are designed to convert to a
soldering flux on the application of a hot iron. Dipping the end of the
wire in a solder pot for a few seconds should od the job too.
If you cannot apply heat, then nail varnish remover can work very well.
It may wick up the strands though. Applying a drop of candle wax first
and stripping and trimming back to the wax should work.
If you don't have nail varnish remover, then I guess paint stripper may
do the job..but nail varnish comes with a handy applicator brush.
Another thing that can work is a gas blowtorch with a catalytic
converter nozzle that turns it into a tiny hot air gun. Loads enough
temperature to remove insulation (or heat-shrink tiny sleeves or in a
confined space).
Hi...
Another idea that's worked for me is to simply 'worry' the
ends gently with a pair of long-nose.
The idea is to slightly crush (over and over :) the strands,
so that the enamel cracks and falls off, leaving the
more flexible copper intact.
Good luck and take care.
Ken
L
legg
Enamel is likely present on both conductors - the 'bare' group's
enamel is just not dyed with distinctive color pigments.
Tin the leads using a soldering iron tip loaded with fluxed solder,
starting from the cut end, where heat transfer to the copper is
facilitated by direct contact. If there are a lot of wires, a solder
pot speeds things up - dip in flux, then dip in the solder pot.
Do not overheat. Better to repeat the process, with fresh solder and a
clean tip, than to persist with a hot tip that has burned out of flux.
The enamel used in commercial equipment is designed for solderability.
Larger bundles of litz, or wires with heavy enamel, may require that
this operation be repeated to contact all internal wires in the
bundle. In this case, abrading the tip to increase bare copper surface
area reduces time in the soldering operation.
Use of an open flame will contaminate, weaken and oxidize the
conductors, making them harder to eventually solder.
RL
W
Will
likely apply solder directly to the wires and the heat will
burn off the enamel while the flux does its job. Some enamels
Hey man, brilliant!
I just soldered the wires and, as you rightly said, the heat of the
iron removed the enamel. It worked a treat.
Thank you.
E
Eric R Snow
Can you advise?
Will
to the beginning.
the wires.
I've done this several times. The technique used is to put the tip of
the soldering iron under the wire so that it just touches it. Then
apply solder and it will melt on the iron tip and surround the wire.
You will see a little dimple where the wire enters the solder blob.
When the laquer burns away this dimple will disappear and the solder
will flow a little way along the wire. Remember you will be burning
off the laquer and the plastic fibers. After tinning all the wires
then they can be soldered together. BTW, I think Sony uses clear,
green, and red laquer. The wire with the clear laquer will appear to
be bright copper but is actually coated. This wire is the common.
ERS
John Larkin
Can you advise?
Will
to the beginning.
the wires.
This is "tinsel wire." It really doesn't solder well, and if you do
manage to solder it, it will soon break at the joint. It's usually
crimped. I don't know how to strip the enamel.
John
Asimov
"Will" bravely wrote to "All" (14 May 05 13:38:12)
--- on the heady topic of "How solder to very fine enamelled woven wires in
earphone lead?"
Wi> Subject: How solder to very fine enamelled woven wires in earphone
Wi> lead? From: Will <[email protected]>
Wi> Xref: aeinews alt.engineering.electrical:22349
Wi> sci.electronics.components:13939 sci.electronics.repair:48119
Wi> sci.electronics.basics:27822
Wi> I have some Sony in-ear headphones. The lead to one earpiece has
Wi> been cut through completely and I want to rejoin the two wires
Wi> (which I will call 'conductors' to avoid confusion).
Wi> The two 'conductors' inside the lead are rather thin. And what is
Wi> more, each of the two 'conductors' is made up of something like a
Wi> dozen smaller copper wires which are woven around some very fine
Wi> threads (perhaps the threads are very fine polyester yarn). The
Wi> threads run along the lead as the core of the 'conductor'.
Wi> The wires of one of these two 'conductors' looks like bare copper
Wi> and is unoxidised so I can probably solder to it. But the OTHER
Wi> CONDUCTOR is the PROBLEM because its fine wires are enamelled.
Wi> How can I remove this enamel coating in order to be able to solder
Wi> to the fine copper wires of the 'conductor'?
There is an enamel stripping liquid available in electronics supply
stores. I generally just run a hot tip over it to singe the enamel a
little then dip the end into paste flux. It usually works but if it
turns into a burnt mess I didn't do it right and start over.
There is also electric arc welding flux which is based on hydrochloric
acid. If this doesn't get the enamel off then nothing will! ;-)
A*s*i*m*o*v
.... "Bother!" said Pooh, as he saw the sparks and smelled the smoke.
W
Will
solder, starting from the cut end, where heat transfer to the
copper is facilitated by direct contact. If there are a lot of
wires, a solder pot speeds things up - dip in flux, then dip in
the solder pot.
and a clean tip, than to persist with a hot tip that has burned
out of flux.
Yup this worked a treat for me! I never realised I could solder
straight onto this stuff by letting the heat of the iron remove
the enamel.
NSM
the enamel.
This is known as "self fluxing enamel". Doesn't work on the old style stuff
though.
W
Watson A.Name - \Watt Sun, the Dark Remover\
Can you advise?
Will
I'm at a los as to why you're posting this to a component newsgroup; it
should only be in sci.electronics.repair. But anyway, each of the
enameled wires is a separate conductor, and should be separate from one
another. Like green might be left, and red right. And the other bare
wires are the common or ground.
L
legg
Tinsel wire is characterized by it's flat spiral winding around the
core. It is not enameled and each conductor will be insulated
conventionally.
It is solderable, but requires mechanical security to prevent
vibration at the SJ. A crimped contact requires the same stress
relief.
The OPs wire is not tinsel wire.
RL
John Larkin
conventionally.
relief.
Oh, don't be crabby. It's a lot of fine conductors woven around a
fibrous insulating core, and it's not very solderable. So it might as
well be tinsel.
So, what's the absolutely correct name for this construction?
John
none
Can you advise?
Will
to the beginning.
the wires.
It's easier and better to just replace the entire headphone cable.
Get oneoff a pair of cheapo headphones.(I get them for a buck at my
local dollar tree and just desolder the leads at the transducers.)
As for removing the varnish insulation you canuse a standard exacto
knife and gently scrape it away or a clean solder tip to burn it off.
Resolder the leads to the Sony transducer elements using a 20-30 watt
soldering pencil, any higher will just melt half the project.(You can
also use a hemostat clamped on the downside of the wire to act as a
heatsink to keep from melting any of the lead.)
Helps to use a good brand of flux and solder.(I use a high silver
content solder, not the 60/40 tin/lead stuff.)
spudnuty
My experience with Sony headphones was as above G=left, Red=Right &
Copper=Common. Sometimes they're actually all wound together, you just
need to tease the colors out. I've usually tinned them using a gun.
Also check the cord down aways as there is probably damage further
along.
All the tinsel cord I've seen used crimp connections or mechanicaly
attached plugs. That goes back to the '50s and my crystal radio set.
My stepdaughter dances around her room with her headphones on. I've
repaired the cord ~ 10 times.
Richard
W
along.
Richard
Same here in the Atari 2600 and Super Mario Bros years back in the '70s,
when a neighbor bought one for his kids. I must've repaired the
joystick at least a half dozen times.
F
Floyd L. Davidson
My kids were just hitting their teens when the Atari 2600 came
along. We bought one, and it was almost never turned off...
After two power supplies burned out, I built a supply robust
enough to last. The joysticks and the switches on the main unit
were all rebuilt *many* times. That Atari finally just got too
hard to maintain, and we bought another one and, except for the
power supply problem, started the whole sequence again.
It was fascinating to watch the kids learn to fix those things.
Initially I had to work on it, but it wasn't long before they
did all the repair work.
Another fun thing about that Atari was the process that we went
through with every new game. I could understand the
instructions better, so I'd win at most of the games... for
about the first half a dozen iterations. That's when the kids
would catch up in understanding what the point of the game was.
Then their reflexes took over, and by the time they had the
experience of maybe 10 or 12 games, there was simply no point in
me even attempting to play against them.
