Deputy Dumbya Dawg
HiC said:I've heard of performers being electrocuted by a mic. If
someone is
performing on a covered stage when it's raining - not
necessarily with
lightning - or any other time for that matter - what should
be
checked/in place to make sure there's no danger to the
performer(s)?
(Other than not performing) Asked another way, what
potentially COULD
create a dangerous situation that some flunkies involved
with stage
operations/sound who don't know better might not check or
just might
fall between the cracks even with pros?
If someone doesn't like to just assume "it's all taken care
of" and
wants to be sure a loved one or friend who's performing is
safe, who
should they typically talk to and what questions should they
ask and
get clear answers to and/or what should they personally
inspect?
Any other stage safety issues that experience has taught you
to be
aware of?
Thanks for all input
http://elvispelvis.com/electrocuted.htm
Keith Relf of the Yardbirds came back from the other side and
told me not to play my electric bass in the bathtub.
But if you are not sure and are standing on the stage with
your bass and a mic giving you the evil eye- or are wondering
about touching any other piece of electrified equipment and
just want to KNOW that when your lips touch the mic you will
not get bit here is a little something you can do that will
let you know the mic will not bite.
Consider this a last advice as a LAST RESORT if all the other
advice in the thread has been followed and you left your
voltmeter home but are still a little scared.
Let the inside of your forearm or the underside of your biceps
touch your guitar strings. The skin that is tender is the key
and if it is a little moisten even better. . Tender flesh will
be much more sensitive to a shock than say your calloused
finger tips and the moisture will assist the current flow if
it is possible and hence you will be more sensitive to a shock
situation. . Now part one of the connection is done. Now with
the SAME arm lick the back of your hand and touch that to the
mic or other suspect equipment.
This does three things.
1) the moist sensitive moist flesh sets up more ideal
conditions for current to flow if such potential exists. The
same effects are exhibited with wet lips and sweaty hands.
2) the current takes a safer path since it only goes through
your arm not your heart.
3) put your flesh in the path in such a way that if current
flows and you are shocked your body's natural tendency to
clench onto what is shocking you is avoided. Your hand may
make a fist if you do get shocked but touching the mic with
the back of your hand will make you pull away from the
shocking element and prevent you from clenching onto the mic
with one hand and the bass with the other until your internal
resistance gets really high ( you are cooked and smoldering).
No shock. Probably safe till someone changes something
somewhere.
peace
dawg
