I have some ideas...
1. If this is to be used in the home, power the LED from a wall
wart. And maybe power the LED through two steering diodes coming
together - one from the wall wart and the other from a backup
battery.
For that matter, get the cheapest actual security camera you can
find from a hobbyist/surplus catalog - even if it's incompatible
with anything practical.
Or further for that matter, find some little professional looking
case and fit some cheap webcam into it and you have a fake security
camera that may actually be made to work in some way as a real one!
Put a red LED on the case...
2. I have an idea for the red LED - make it glow continuously like
those on real cameras that have LEDs do. Get a GaAlAsP red LED,
peak wavelength 660 nm, 3000 mcd (with a usual beam width of 15
degrees but sometimes claimed more), such as Radio Shack 276-307.
Red LEDs of same/similar chemistry and efficiency are Agilent
HLMP-8103 and HLMP-C124.
Get some fine sandpaper and sand down the tip by about a millimeter
then restore the "bullet" shape but about a millimeter shorter and
with the tip very slightly more blunt, then get some really fine
sandpaper and get the LED good and evenly frosted. After that, you
have a super high efficiency diffused wide angle red LED that works
well and reliably at 1 milliamp, and may be bright enough at half a
milliamp. It will glow with a color close enough to that of lower
efficiency red LEDs.
If you really want to go all out, get an InGaN green LED (nominal
wavelength usually 525 to 530 nm) of the common 5 mm "bullet" style
and give it the sandpaper treatment described above. Then give it
half a milliamp or maybe a quarter of a milliamp. Most Nichia 5 mm
green ones and those trying to compete with them (ETG, and others)
should at half a milliamp have a brightness that I consider "fully
that of a usual green LED indicator light". Furthermore, the
wavelength of these tends to shift a little inversely with current,
and at half a milliamp the color is likely to be about that of LEDs
with nominal wavelength in the 550's nm, maybe close to 560 - a
yellowish shade of green likely to look enough like a usual 565 nm
green LED indicator lamp to look like a usual indicator LED to most
criminals.
A pack of (4) AA alkaline cells with a 6.8K resistor should power
such a green LED reasonably well 24/7 for at least half a year.
If you want an LED to falsely indicate presence of a security
system in an automobile, don't worry about conserving every
milliamp since the battery has self-discharge in the 10's of
milliamps. You can afford a few milliamps to protect a car.
- Don Klipstein (
[email protected])
