How Does Digital Video Work?
David Lloyd-Jones
We learned in skule how a TV set works: a flying beam rasters down the
screen, energizing phosphors on the back of the glass; different
phosphors for different colors; higher energy beam for brighter
spots...
Where could I find an explanation at roughly this level of generality
of how video cards and digital "screens" work? How does a photograph,
or a data-base of X-million numerical values, get turned into a
picture on a plasma screen? A Jumbotron? The outside of the NASDAQ
building in Times Square?
I've Googled like crazy around this question, but end up swamped with
stuff about what is the best video card for your gaming fun. "How-to"
searches get me how to put in a video card. Still, Google pointers
would be handy.
TIA,
-dlj.
Bob Myers
I don't know quite what level of detail you want, but there are
any number of texts that cover the operation of the various
non-CRT display technologies (few of which, by the way, are
truly "digital" - LCDs AREN'T, for instance). I could even,
at the risk of putting in a plug here, point you to my own book:
Display Interfaces: Fundamentals and Standards
.... published as part of the SID/Wiley Display Technology
series by John Wiley & Sons. But there are certainly a lot of
other sources, too.
Bob M.
Tom MacIntyre
spots...
would be handy.
TIA,
-dlj.
Did you try here? There may be something...
http://www.howstuffworks.com/
Tom
R. Steve Walz
spots...
of how video cards
A video card is a bank of RAM that is dual-port, it can be read from
and written to at the same time, or just RAM that can be written to
and read from alternately fast enough, to be used by a video generator
chip, or a set of counters and logic, to assemble the typical NTSC or
other kinds of video streams and route them to one or several outputs
for multiple colors.
-dlj.
The general process is the similar raster process, you scan a pixel
and then a line at a time, using decoder/demultiplexers and counters.
A photo gets digitized by sensing color and intensity in a region and
then approximating it as a single pixel of a specific intensity and
color balance of red, green and blue.
The multi-CRT over-large TV "walls" use counters to count pixels and
lines, and arrange to extraploate/interpolate pixel reductions or
expansions, often using dithering and other focal info-tricks and
route them to the correct new re-assembled video to each separate
monitor.
The purely pixel-field digital screens use a memory "backing" for the
emitter plane, and it writes to that memory to refresh to the new
image, some schemes blank it, some do not, or use more bit-tricks to
avoid ripple and aliasing.
Scrolling signs are merely demuxed addressing with latches or
shift-registers feeding LEDs
-Steve
H
H. Dziardziel
spots...
would be handy.
TIA,
-dlj.
http://www.pctechguide.com/sitemap.htm
