household outdoor/wet location connections
Don Y
I have CATV/phone/network connections in several places
on the outside of the house. Of course, these have to
be "weatherproof" (just for the sake of the connectors
themselves).
I initially had the connectors "exposed" under a hinged
cover (that was not intended to seal watertight. This
was kind to the cabling mated to the connectors. But,
left the connectors more vulnerable.
I replaced these (covers) with spring-loaded, "water
tight" covers which protect the connectors better
(when NOT in use). But, the spring-loaded doors put
lots of stress on the cables *mated* to the connectors.
So, I'm looking for yet another option. Perhaps something
*designed* for outdoor use (so far, the connectors I have
used have NOT been "special" in any way).
Ideally, connectors/covers that treat each connection
individually -- so exposing one connection doesn't
require exposing another UNUSED connection (e.g., think
in terms of duplex receptacles). Maybe even the REALLY
old fashioned "screw cover" plates?
Thx,
--don
PeterD
themselves).
Thx,
--don
We always used a rubber compound to seal those connectors. Lot's of
sources, used on both communications and in automotive work (to seal
holes, and such, in vehicles. Never hardens, very sticky, usually black
(but you can get gray). You kneed it for a while to warm it up and
soften it, then work it around the connectors. Very water tight. Very
hard to get off the hands when done, but hey, that's life.
Rich Webb
themselves).
Look at Amphenol's RJF families. The RJF 544 types aren't *terribly*
pricey and they are rated IP67. They use standard "RJ-45" connectors
internally, so there are no special issues regarding maintaining the
twist or pair matching, etc.
Don Y
Hi Peter,
That would be fine for sealing *inside* the connectors (wire-side).
But, using it on the mating face would imply you aren't going
to ever *separate* the connectors, right?
(Silicone caulk also works well. For buried connections -- like
landscape lighting -- I run the wires into an old "pill bottle"
and then pump it full of silicone caulk, wait for it to "cure",
then bury in soil.)
I.e., I want to be able to plug a phone, TV cable, computer, etc.
into one of these connectors WHEN I NEED TO and then *unplug* it,
later -- and have the connector that remains be protected thereafter
(i.e., by a watertight door, etc.)
Don Y
Hi Rich,
It doesn't look like the jack is protected when *not* mated (?).
Though mated looks to be an ideal solution!
I will have to look at some dimensioned drawings to see if I
can hide it behind a conventional hinged cover or similar.
Anything *like* these for the phone and CATV?
Rich Webb
Hi Rich,
They also have IP67 caps available, of course. The product's PDF flyer
has dimensioned drawings and it looks like they'd fit into a commercial
weather box.
Sure. Mil/aero/marine/industrial services use connectors designed for
harsh environments all the time. Amphenol RF is one place to start but
there are many others. Be warned that price goes up with ruggedness.
Don Y
Hi Rich,
weather box.
OK. Looks like they have covered the case of mated and *not* mated.
Interesting to see firewire, usb, etc. connectors offered as well.
Obviously, they are thinking in terms of equipment cases (not
"back porches"! :> )
I didn't see anything suitable for RF. E.g., F connectors.
Maybe I can find a similar bayonet connector and use that
(since the cable that mates to it will need the "weatherproof
hood", I can just as easily put a BNC connector on one end
and F on the other)
I'm looking at onesy-twosies so cost isn't a big deal.
Thanks!
Jasen Betts
Hi Rich,
and F on the other)
You won't find special weatherfproof F connectors,
because that's the only type there is.
just screw a terminator cap on it, that's what the cable guys
do on the unused ports of their splitters.
The one I found on the ground looked a bit like this,
http://search.digikey.com/us/en/products/222154/ACX1473-ND/1989922
dunno if they make a version with an O-ring inside, but if you face the jack
upwards it's not going to leak much with the cap on.
Don Y
Hi Jasen,
<frown> I've looked at connectors left "out in the elements"
that don't look too good. E.g., even connectors at the masthead
have rubber hoods, etc.
I have similar terminators on my *indoor* connectors.
But dealing with the elements also involves the space *around* the
connector/bulkhead. E.g., you can put this behind a typical NEMA
"wet location" cover. But, then whatever is in the "other half"
(think: duplex receptacle) of the fixture has to be compatible with
that sort of cover. (consider the connectors Rich mentioned
previously -- I want RJ11, RJ45 and F connectors available in
each "location")
Ideally, I would like to find a "family" of connectors that
solves this same problem in similar ways -- so I can come up
with one packaging approach instead of "do this for this half
of the connection point, and THIS for the other half..."
Currently, I'm pursuing the ANCIENT "wet location" covers
(round screw on caps) so I can adopt an *indoor* connector
solution and just overlay the "wet location" caps on that.
Thomas
Don said:
Hi Jasen,
each "location")
I used a standard *INDOOR* wall keystone-type plate, cut down to fit within the
inside width and height of a weatherproof-while-in-use receptacle cover. I left
just enough height on the wall plate to allow me to bolt the plate to the cover.
So far it has worked admirably for over ten months.
-- Thomas
Don Y
Hi Thomas,
On 2/9/2012 1:47 PM, Thomas wrote:
[elided]
within the inside width and height of a weatherproof-while-in-use
receptacle cover. I left just enough height on the wall plate to allow
OK. In my case, I'd have to use these "component" wallplates
(i.e., mix and match various different connectors and combinations).
But, the actual wall plate is pretty *thick* (front to back).
I suspect this is because the "front surface" effectively has
to support these "plug in, modular connectors".
So, the "cap" that covers the connector is deep enough to
clear the extent that the connector protrudes beyond the
"front surface"?
Did you remove/disable the springs that would normally hold
the "cap" closed (protecting the connector)? (all of the
covers I've seen -- that *seal* -- are spring-loaded)
If so, how effective is the seal without the spring tension?
If *not*, how do you handle the stress that it puts on the
"back side" of the cable-to-connector joint of the *mating*
cable? That was the problem I experienced -- if I left a
cable plugged in for a prolonged time (much of the year is
temperate here so you can easily leave a phone, TV, etc.
out on the porch for months at a time), the cable became
flakey because of the constant pressure on that flex point.
I.e., if you unplugged the cable, it invariably looked like
an "L" -- with the wire being the upright portion of the L
and the connector the other! This isn't as bad for bulky
coax but was a killer for phone/network.
(I also wonder how much of this stress is transferred to
the stationary connector's contacts)
The connectors Rich pointed out were great because they
looked like they would be protected when NOT in use as well
as when *IN* use (though with that obvious "MIL feel").
Thomas
Don said:
Hi Thomas,
Note the *weatherproof-while-in-use* above. These covers are designed to have a
power cord plugged in and the cover closed *without* placing undue stress on the
cord-to-plug area. All the ones I've seen at the hardware stores and home
centers (Lowe's, Home Depot, etc.) are transparent or semi-transparent.
The keystone plate I used (in fact all the plates I've used over the years) are
no thicker at the edges than a standard plastic indoor wall plate. The area of
the plates that the keystone-style jack (be it modular, RCA, F, etc.) is
box-shaped to accommodate the jack insert. This area extends into the box, so if
you go this route ensure the box you use is at least deep enough to account for
this as well as leaving enough room so as not to stress the connections *inside*
the box when the plate/cover assembly is screwed to the box.
"front surface"?
Your thinking of the usual weatherproof cover, which is not allowed per the NEC
in the US except where shielded from direct exposure to rainfall, e.g
house-side wall of a porch (other countries have similar rule?).
Where exposed to direct rainfall, all receptacles must be fitted with with
*weatherproof-while-in-use* covers. (IIRC this was mandated in the NEC back in
2005).
With the spring-loaded typically gray duplex covers so abundant everywhere (and
a lot of them don't meet today's NEC in the US) I understand your thinking of
this type of cover here. I've yet to see a weatherproof-while-in-use cover
anywhere (aside from the ones I myself have installed)
This is why I used a weatherproof-while-in-use cover for my outside phone jack.
No stress on the cable-to-plug connection nor the plug-to-jack connection.
The cover I used wasn't exactly cheep: about 12USD for the one I purchased at
the hardware store. Well worth it, though.
God Bless.
Don Y
Hi Thomas,
Ah, my bad.
Understood. The ones I installed for the electric outlets are made by
"Red Dot". Cast out of <something> -- both the plate and *cover*.
They come in two different orientations -- horizontal (so the "outlets"
are located side by side) and vertical (outlets above each other).
This affects where teh hinge is located.
I opted for the horizontal orientation as power cords don't have to
lay on top of each other as they try to exit the cover.
The problem with these is that they aren't "sealed" when not in use.
E.g., I've encountered AC receptacles with *plugged* ground "holes".
It appears that certain insects find places like this to lay
eggs (?) which they then "seal" in place.
These actually have reinforced areas behind the "mounting holes"
because the face of the plate (which is what the mounting screw would
bottom *into*) is so far above the "seating plane" of the plate itself.
(I noticed this when purchasing them as the plates would have cracked
from mechanical stress when "tightened down", otherwise)
I.e., I may have to just find some other plates.
Yes, I use what are called "deep" wet location boxes. A good three (?)
inches from front to back -- *plus* an additional ~3/4" "extension"
attached to the face. More space (volume) is always better than less!
Especially when you are trying to bend RG6Q *in* the box.
2005).
Understood.
I see the "spring-loaded" covers sold everywhere. Even new designs
(e.g., for GFCI's). Though the "screw on caps" from ~50 years past
seem to be gone (maybe I'll try a surplus yard).
Understood. But see above.
When I removed one of the trim boards that runs the length of the
house, it was *filled* with tightly rolled "leaf cuttings"! I
guess there is a bee/wasp that literally cuts the leaves off of
certain plants (i.e., chews across the leaf to cause part of it
to fall off) and uses it to protect its eggs?
Too many damn critters! I wonder what will happen when I move
the kiln out there?? :<
Thomas
Don said:
Hi Thomas,
Ah, my bad.
One detail I forgot to mention: the cover I used is the GFCI style, not the
standard duplex. By trimming the indoor keystone plate to fit the rectangular
hole in the cover and bolting the plate to the back of the cover I made a custom
weatherproof-while-in-use phone jack cover.
If I had a camera I would take a picture for you so you could see exactly what I
did (picture being a thousand words and all) but alas I'm not that fortunate...yet)
(I used an RJ-45 jack and plug; this permits not only the one voice and the DSL
lines, but allows two more voice lines in the future. I try to think ahead and
allow for future expansion/use whenever I do something like this. I felt
allowing for three voice lines was plenty. As it turned out, my wife would like
an office for her (very small at the moment) business; dedicated voice and fax
line for this can now be easily added because of my foresight.)
I Hope this helps.
God Bless.
Don Y
Hi Thomas,
<frown> I can picture the cover and "fitting" the plate into it.
But, can't see how you'd fasten them together once that is done.
I.e., the difference between the traditional duplex "wet use cover"
and the GFCI variant is (besides the shape of the hole(s)) the
presence/absence of that "cross piece" between the two outlets
(which has a mounting hole in it).
Not to worry. I will look at one of them on my next visit to
Home Despot/Glowes/Space/etc. I vaguely recall the wet use cover
having LOTS of mounting options (to the wet use junction box);
no doubt to cover different configurations that might be
encountered. So, there is probably a set of suitable holes
that you availed yourself of that I can't envision...
Understood. Inside the house, each wall plate has three connections:
phone, network and "antenna/cable". I opted to use a *red* RJ45
connector for the network connections (the wallplate itself is white;
as are the other "snap in connector modules"). I felt this would
help safeguard against "phones" being plugged into "network" outlets.
This also makes it easier to visually identify where you want to
plug in your laptop, etc.
(I have a box of ~500 such RJ45 "modules" in various colors. Red seemed
the most visually distinguishable. It *says*, "there is something
different about me; think twice before you use me!")
Yup. Originally I had a 25 pair cable connecting the telephone network
interface to the distribution panel (punchdown blocks) in the house.
When I ran the (2!) RG6Q's for the CATV feed, I opted to replace it
since I wanted to save myself the hassle of drilling another hole
through the masonry to get the wires to the outside of the house.
(the existing hole wouldn't have been large enough for the two RG6Q's
*and* the 25 pair telco cable).
I could then have chosen to run some 12 pair to replace the 25 pair.
Or, the two CAT5's. Since all of the above were more than I'd
ever *need*, the CAT5's won the day! (again, with the realization
that I could eventually put a truly high speed interface on the
other end of the wire -- when/if the "utilities" decide to move into
the 21st century)
Thomas
Don said:
Hi Thomas,
I drilled my own holes in the plate, then marked and drilled the holes in the
cover. You don't need very big bolts. I used #6 bolts (with washers on the cover
side) to fasten the two together. 3/4 inch long, IIRC.
Use the GFCI snap-in, then trim the wall plate to just fit the cover without
interference with the box when the cover is attached. Again, I trimmed the wall
plate just enough past the hole (towards the center of the plate) to allow me to
drill mounting holes in the plate *and* not interfere with the mounting post in
the box (if FS type (PVC) box), or the device mounting tab (or plate) in the
metal box (which I used). (I've seen metal boxes both ways: with tab/plate and
post style device mounting methods. I've only ever seen FS boxes with posts.)
I used blue, mainly because thats the only ones I could get at the time. (The
RJ-25s where almond/beige.) And they matched the cable I used (the jacket was
blue. ;) )
Just a note: my preference is gray-jacketed cable for voice, blue for data.
Color-coding saves a lot of confusion, yes?
the 21st century)
The wife and I discussed at one point that if we ever built a house, we would
not run coax everywhere. Instead, we would set up a low-end-ish tower with four
video capture cards in it and enough hard drive capacity for about 200 hours of
recording, install openSUSE on it (the hardware requirements for openSUSE are
minimal), then set it up as as a video recorder. Attached to the capture cards
were to be standard, non-DVR satellite receivers (DirecTV or Dish, whichever was
to best value) set up so the PC could control them.
Since we would pretty much have a PC where we wanted to watch "TV", including
the living room, this would not be a problem. Since we also rip our CDs and DVDs
to my computer (it has the HDD capacity), setting up a media server made sense.
With the satellite receivers connected to the "video capture" tower, which would
have been set up to allow us to transfer those recordings we wanted to keep long
term to the media server, we effectively would have created our own four-channel
DVR. (If you have a satellite-provider provided DVR receiver and forget to pay
the bill you won't be able to watch any recorded material once your service is
cut off. The DVR functions are disabled along with the regular view-only
function. I suspect cable equipment works the same, yes?)
Just an idea.
And I agree with you on the utilities being stuck in the last century.
Don Y
Hi Thomas,
Ah, OK. You changed the rules ;-) I've been trying to recall what the
wet location covers, etc. that *I've* used looked like (without actually
removing one from its mounts) and how you made use of that. :-/
blue. ;) )
My other half wanted white. Until I pointed out how hard it would
be to look at two similar looking connectors (RJ11&45) and get the
"right one", without careful examination and thought about the
connector IN YOUR HAND. (I've been cherry picking red "patch cords"
and putting them in the laptop cases to drive home this issue)
I ran (white) CAT3 for phone and (blue or grey) CAT5 for the network
stuff (that's what I had on hand). Or course, the RG6Q is obviously
recognizable (black and *thick*!).
I had thought about running two CAT5's to each drop (instead of a
CAT5 and a CAT3) to be even *more* "future safe". But, seeing that
the CAT3's would be terminated in an entirely different place
than the CAT5's (i.e., not suitable for adding a network switch
near the punchdown panels at a later date), it seemed best to just
live with the three different cable types.
Coax as in "CATV".
This is exactly what I've been doing. Though extending it to encompas
audio and automation, as well.
I got tired of all the little piles of "consumer kit" cluttering up
the house. DVD player, "stereo" amplifier, CD player, TV tuner, TV,
speakers, etc. in each bedroom, family room, living room, etc. (Gee,
what if I want to sit outside and watch TV? Weather is always
"fine"...)
So, I ran CAT5 *everywhere* when we were remodeling (e.g., there are
four separate drops in the living room alone -- so the TV can sit in
any corner, etc.). But, I got nervous about NOT having phone and
CATV in those places: what happens when you sell the house and the
new owners aren't as "tech savvy"? ("Martha, where do we plug in the
PHONE?? And where is the cable TV connection???!").
"Wire is cheap" so I ran one of everything (if you don't need/use it,
replace the wall plate with "whatever" is appropriate and push the
wire back into the wall cavity). There are drops that feed speakers
mounted in the ceiling for background music, audio announcements
("Someone is at the front door"), etc.
I also ran CAT5 drops to the four corners of the house (think: PTZ IP
cameras), front porch (so you can see who is at the door!), etc.
And, additional specific drops for other "special needs" (e.g., to
the irrigation system controller, HVAC controller, etc.). There are
drops for bluetooth modules scattered around the house/property to
allow roaming devices to be "located" (I.e., I can wear a BT earpiece
or use a BT enabled PDA or cell phone to "talk" to the house as well
as having it figure out where I am: "Ah, he wants to watch _Buckaroo
Banzai_ in the *family* room..." -- location-aware computing)
Toys for retirement! :>
(actually, there are several different technologies involved that
I am exploring or developing for clients... being a guinea pig is
a great test platform!)
I think there are some older Tivo's that will work even after the
subscription has expired ("disabled"). I am thinking of one sitting
in a friend's shop... I will have to examine it and see, for sure.
But, MythTV or any of the commercial DVR software packages (usually
come with "camera cards") would also work (dubious quality). Content
providers don't want you having (legitimate!) copies of content.
They'd rather have you pay for *each* viewing of that content!
I've been accumulating (ahem) "broken" DTV STBs with an eye towards
a poor man's multichannel OTA DVR. The tuner is the tough part.
Once you've got the signal off the airwaves, the rest is just busy
work.
Just an idea.
One that many folks share ;-)
<shrug> No pressure on them to change.
Don Y
There's two ways to weatherproof a splice; one is to seal it
Sorry, "splices" aren't the issue (perhaps I should have said
"connection points"? "outlets"? :-/ ). I.e., "I want to
plug in a phone/computer/TV on the back porch -- which is
sometimes subjected to the elements."
with a wrap of fusion tape (a rubbery self-adhering tape,
available in rubber or silicone variants), another is 'liquid tape',
which is painted on.
Then, you put some enclosure around it (nowadays, often a
heavy heatshrink tube), and then you can bury it.
For direct burial, I put the "splice" in a "pill bottle" and then
squirt silicone "caulk" into the bottle until it is full/solid.
Then, throw the whole thing in the ground.
The bottle gives a form to the silicone (just trying to squirt
silicone on a splice is messy and doesn't guarantee the
silicon won't "ooze off" before it sets). And, it makes the
splice easy to handle as you are setting it in the ground
(no need to wait for the silicone to dry completely).
If the splice is far inside the bottle, the silicone seals
around the *edges* of the removed insulation, as well. This
keeps moisture from wicking up under the insulation and corroding
the wire(s). (I *think* you could probably set the splice in a
bucket of water without fear!)
And, above all, it's CHEAP! :>
Thomas
Don said:
Hi Thomas,
Sometimes you have to change the rules when there's no other option, as in this
case.
Why aren't weatherproof covers available for communications jacks (phone, data,
cable/sat, etc.)????? Surely there's a market for such.
God Bless
case.
There are and there is. However, The market is obviously smaller than you
think it is (they cost more than a nickel).
