KrisBlueNZ
Sadly passed away in 2015
I think it's best if duke37 advises you on this project. I'll answer the questions I can.
I don't know what the item labelled SCHUMACHER is. Fuses normally only have two connections. I can only make out 12V and 12A in the marking, and Googling Schumacher 12V 12A -Michael shows that Schumacher make batteries and chargers, but that doesn't tell us what that component is. If there are any other markings on it, you could try Googling those. Can you show how it is connected in the charger circuitry? Also, does it have any other features apart from the three contacts?
Your schematic is not quite right. You have the capacitor connected in series with the supply to the PWM module. The capacitor and the PWM module should be connected in parallel with each other, across the DC output from the transformer-rectifier combination.
Assuming the rectifier diodes have commoned cathodes, as you've shown, that is the positive output of the transformer-rectifier combination, and the centre-tap is the negative output. Connect the capacitor and the PWM module across those points in the circuit.
How does the 2A/6A switch hook into the wiring? Can you draw a schematic of the charger in its original state?
Yes, a zip tie or two is a good way to secure the capacitor.
