Hi guys,
Need help. Bought this air horn set for my motorcycle.
https://www.amazon.com/SEGER-Trumpet-Car-Horn-Set/dp/B07PDF7GTL
I also made the attached wiring diagram using just one relay to power both horns with one line.
My question is whether I should consider using 2 separate positive lines from the bike battery with separate fuse and relays to each horn instead. I will then splice the original horn wires to act as the triggers to both relays simultaneously. How would you do it?
Thanks,
Ron
Thanks,
Ron
