hilfe uber 18150Z SOP6 SMD?!?
U
upsit
does anyone knows what component is 18150Z, SOP6 package SMD (2 x 3 pins)
its in circle of power supply of portable DVD player...i guess it could be
some voltage buck converter....cant find any datasheet at all ?!?!? i need a
datasheet of it or information what can be replacement for it?!?!
thanks
Jamie
thanks
If you can't not identify the purpose of this chip, what makes you think
it is bad? Is there big gaping hole in it?
Jamie
U
upsit
Jamie
i am sorry for being arogant, but your question/conclusion is a bit lame :))
......well, of course i am not asking just for curiosity....the component is
burnt out (smoked) so it is completely logical that i am asking about this
particular component to replace it with new one or replacement that can
suits there....
and purpose of the "chip" (more likely is about the complex MOSFET) is
definitely about power control in any sense since it is in serial connection
right after DC power jack 9 - 12 Volts input...
btw; are you even in electronics at all?!?!?!
i have a dozen of AudioSonic portable DVD players and all of them have the
same problem; that part is burnt out and it wont work....
i bought a working one, opened it and found out that compnent is marked as i
already wrote it.....so, to replace it, i need to know what am i
replacing....coz Google does not recognize that SMD marking....
V
Vote 99% Greens
pins)
could be some voltage buck converter....cant find any datasheet at
all ?!?!? i need a datasheet of it or information what can be
thanks
Are these any help?
http://category.alldatasheet.com/index.jsp?sSearchword=PHOTOCOUPLER SOP
6-SMD 6-smd
(http://category.alldatasheet.com/index.jsp?components=PHOTOCOUPLER SOP 6-SMD 6-smd 6-SMD 6-smd)
http://www.alldatasheet.com/view.jsp?Searchword=18150
