DaveC
My toaster resurrection project
Need to (re)connect the nichrome wire to the insulated, stranded supply wire.
The existing (now overheated and useless, due to heat via bad connection)
connection is a rivet (stainless?) with the nichrome wrapped around the head,
and a brass (looking) crimp on the backside that accepts the supply wire.
Barring an original replacement item, what replacements would you recommend?
Most crimp ring terminals aren't brass. Should I use brass? A rivet would be
difficult to install here. Would a threaded fastener (nut & bolt) be
sufficient? Stainless?
Thanks,
Please, no "Go Google this" replies. I wouldn't
ask a question here if I hadn't done that already.
DaveC
[email protected]
This is an invalid return address
Please reply in the news group
Thanks,
DaveC
[email protected]
