High power LED power/driver question.
I have 8 high power "3Watt" LEDs setup in series. They Are 3.2-3.8V, 700mA. If I did the math correctly. I have to get a power supply that is 30.4V @ 700mA. Is this correct? Also, I'm Confused as to weather or not I need a driver. I've google searched it, but I'm still slightly confused as to the purpose of a driver. Anyone know where I can get a power supply with this rating?
Any help is appreciated.
At least.
You'll need some form of current limiting. Otherwise the LED current is not controlled and can lead to thermal runaway, burning your LEDs.
Either a series resistor or a constant current LED driver. Both will require a higher input voltage than computed above.
Example: Using a 2.2 Ω / 2 W resistor the voltage drop will be dV = 2.2 Ω ×0.7 A = 1.54 V, therefore the output of the power supply needs to be 30.4 V + 1.54 V = 32 V.
