Hi, can someone help me to build an led circuit? i wan to build a study light for my nephew birthday
1st of all i do not have electronic background. im just like to build something by myself.
im self learning on the internet/books. so i want to build an led driver that can light at least 4-5 power LED. i already build it b4 this but just using a linear converter. now i learn that it is not efficient. i try search then i found buck converter. then i design a buck converter circuit. this is what i design btw.
*replace the resistor with LED
then i dont know how to proceed
i read that led has max current. higher than that led will burn. but buck only regulate voltage right?
how do i make it constant current so that led dont burn? i wan to add resistor series to the led but then i read that it also not efficient, better use linear then.
i also wan to make the led dim. can i just adjust the pulse? will the led dim?
how about pwm? 555timer will be enough?
*sorry for my english
thanks
