If you can't fit an SMT quad op-amp package and 4 resistors you're TOTALLY screwed anyway ! I
can't imagine ANY other solution will take less space.
Just how much space is there ?
I don't know why you say it is *just* these parts. The point is that
I have two channels with differential outputs, so four outputs. Right
now I am using three 20 pin TSSOPs with a *bunch* of passives. I
don't get why you say there are *only* four resistors... That is
pretty far off the track! The current parts are duals, so I get both
the A and B output of one channel in each package and a third for the
two input amps used as differential to single ended converters. There
are filters, feedback resistors, decoupling caps and the list goes
on. Then the output resistors are the ones that have to be *HUGE* to
handle the power. Do the math... 0.1 Apeak into 50 ohms is 0.25
watts. If the output is shorted, it becomes 0.2 Apeak and 1 watt. A
1 watt resistor is a 2512 size X four outputs equals a lot of board
space that you can't put vias into. The opamp has to dissipate 0.35
watt normally, with a shorted output it rises to 0.68 watts. That's a
30 C rise with the optimal PCB layout which includes a large copper
area on the bottom where you can't put other parts or vias or run
traces... I can show you the gerbers of my half completed layout.
After trying to find ways to shove 10 pounds of parts and vias onto a
5 pound board, I realized that it just would not fit and now I am
looking for new ideas to make it fit.
I have opamps that will drive the required current *and* the voltage.
But the one I picked just will not fit the space available with the
current design using those huge resistors (actually four 0805s instead
of one 2512). Trying to use four opamps to do what I can do with one
opamp is not really a productive step.
But thanks anyway. Going over all this helps to keep it fresh in my
mind. When I encounter a difficult design, I tend to want to find a
way to make it work. Then I drive myself until I am totally sick of
dealing with the problem and often have started to work way too late
and am loosing sleep over it. That is part of why I came here. If
nothing else, it gives me a chance to think about the problem and not
just obsess with trying to make a bad solution fit.
Right now I am pretty happy with two possible solutions. There is a
Fairchild part that should either meet the requirements of 10 Vpp into
50 ohms with none or a small series resistor (maybe 5 ohms) for
stability. Since the part is not really spec'd in this range, I can't
be sure it will drive the full voltage, but the data given sure makes
it look good. The part is cheap, the single 12 volt supply saves a
lot of power burnt in the opamp. But it has no spice model, so I
can't check it before building it. I will have to verify everything
on the lab bench where it is much tougher to measure things like
currents.
The other solution is an audio amp from TI which *does* have a spice
model. It is also cheap and available. But it uses the +- 12 volt
supplies and will be pretty warm. It has differential outputs, but
the best thermal package is 10 x 10 mm which is large for this socket
and the thetaJA is still a wopping 80C/W, so I am not sure about the
effect of the power. It is also a fixed gain device, so would require
driver opamps to set the gain of the output (that may be a minor issue
since the two input amps can share a quad package with the drivers).
Finally, this won't drive 10 Vpp, but rather tops out at about 8.5
Vpp.
Yes, the board is really small, 4.5" x 0.85" and most of it is FPGA,
connectors and some RS-422 driver/receivers, analog switches for
isolation, ESD diodes, two power converters an oh don't forget the
codec. Worse, I am constrained by the existing design to put the
connectors, one near an end of the board and one a little past the
middle. All of the analog stuff should go between the two connectors
and the digital on the long overhang.
So there is the current solution that meets all of the requirements
other than fitting the board space. Then I have an audio amp that is
pretty hot and won't drive the full voltage into 50 ohms, but looks
fairly good in other regards. Lastly, there is a opamp from Fairchild
that looks like it would do it all and from a 12 volt supply as long
as I give up the 50 ohm output resistors, but it has no spice model to
simulate.
I do appreciate the comments and just conversation. I helps me get it
all straight in my head. I have always known that if someone can't
properly explain something, it is because they don't really understand
it. So if I can't explain it to you, I don't understand the issues
here. By trying to explain it, I learn it that much more clearly.
