"rickman" ...
High resolution? I hope it is not also high accuracy.
A long cable with a 50 Ohm load will have a gain certainly less than one.
And temperature dependent. How are you (is your) customer dealing with that?
You are not doing remote sensing, are you?
"High resolution" is the customer's term for better than voice grade.
I am using a standard 16+ bit codec which can sample at much higher
rates than what is needed for audio. That is what he essentially
asked for. I have been given no details about how the voice grade
mode or the "high resolution" mode will be used. The voice grade mode
I can figure out easily as I have the info on their current design and
voice is pretty standard. It is the 50 ohm mode that I am actually
building for him. But he would like this new card to replace the old
one and pick up the "high resolution" mode as well... if possible.
The issues of driving cables and varying loads aside, this card will
do that. The rest is up to him since I was not given info to work
with.
My only real concern with the Fairchild part meeting the spec for all
of these modes (which can have different build options, btw, so
resistors and such can change) is driving a capacitive load. They say
to use an output resistor to isolate the capacitance. But if I use a
very large one, it will reduce the voltage level. That is why I would
like to simulate it, there are just too many variables to try to get
it right the first time without simulation.
