Platforms
Content
Hi, Kelly, so that is tuned circuit, C1 and Inductor,, they resonace at 11.25Mhz, but i dont understand, what happen when is lower frequency or higher frequency than 11.25MhzThe resistor and inductor associated with C1 are representative values (parameters) for the losses in C1 and allow you to make a more accurate calculation for resonance and/or Q. Same applies for the resistance associated with L2.
GoodMorning Duke, so you mean only at that frequency will work Q1, otherwise there is no feedback?, because i have one software feedback analysis, is very easy to design the circuits, after i build the circuit in multisim and i make experiment andi i dont see anything change in voltage of current, when i change the frequency still is working?It will not work. Q1 has no power.
Yes of course that not work, let take example that RC is resistor is connected for example to 12V power supply, a 1V peak input, now i dont understand what they do lc, you can use one resistor feedback...……..No, it wont work at all ... the circuit shows no power supply ... you cannot sim a circuit that has no power
I think feedback is thrugh tuned circuit and resitorMichael...so you now really understand the meaning, the task and the characteristics of the two feedback loops in the circuit? (I hope you know that R3-L2 also provides feedback). I would be surprised...
I think feedback is thrught tuned circuit and R1 of rc circuits,...……..the emitter resistor is to bias and also gain, and l2 the same but he deopends from frequency low or high imedance and also gain…….Michael...so you now really understand the meaning, the task and the characteristics of the two feedback loops in the circuit? (I hope you know that R3-L2 also provides feedback). I would be surprised...
Ohhh Realy i am sorry, that i did not open the forum, realy i am sorry, i thougt is finish i understand, and i thought i understand, for that i did not open the forum,Regarding DC bias: The circuit has no biasing voltages at all.
And - as mentioned - the emitter resistor provides negative DC feedback (and - yes- contributes to bias) and R3-L2 provide negative ac feedback!!
What is the purpose of R1-L1-C1 feedback path? Does it always work as a feedback loop?
Why a series resonant circuit?
Michael - I am asking these questions because your answer was "....I understand now...!-
