Help with transistor replacement
Hello, i'm trying to replace a burned transistor on my synth.
Original is a B731 E / D48. (here :http://imgur.com/WpmaRIm) I was following a tuto from a guy who's had the same problem, so i ordered the same transistor he used in replacement, but i just saw he used B744 instead of the original. It seems it's not exactly the same characteristics and voltages ?
So i was searching for B731 but i found these : http://imgur.com/jLQfBhm which are labeled as B731 E / D33. What does this last number mean ?
In short - can i replace a B731 with a B744 ? What does D48 , D33 mean ?
davenn
most likely a manufacturing date code .... not important
the B731 ( 2SB731) is the important part
have you looked up a datasheet for the 2 transistors and compared their characteristics ?
do so, and that will tell you if you could use the B744 as a replacement
Dave
Yep i've looked at the datasheets and the voltages values are : -70 / -60 / -6 for the SB774A, and original transistor is -60 / -50 / -6
I put below the original schematics section : it seems to me that the 744 is replacing the 731, but would love your advice :)
