I hope someone can give me some pointers with a problem I have with an audio circuit powered from a 24VDC switch-mode PSU. The 24V circuit also has some incandescant lemps attached which add a burden of 230mA to the 24V supply. Without the lamps in circuit I can hear a small amount of high-frequency background noise. With the lamps in circuit, the noise disappears as though the lamps are providing some sort of damping. If I halve the lamp burden the noise re-appears, but not so loud.
The PSU exhibits the standard sort of noise bursts normally associated with a switcher, and the only change I can see is that the leading edge of these bursts increases with the lamps out of circuit, but the increase is not on every burst, so I suspect that what I am hearing is the modulated result.
I want to change the lamps to LEDs, and as this circuit needs to be battery-powered I can't really afford a 230mA burden.
I've attached some waveforms of the PSU +VE rail, AC coupled, 200mV full scale, 500ns/div.
Any clues as to eliminate the noise would be greatly appreciated.
With Lamps
without lamps
With Lamps
without lamps
