Yes, that is correct.That is interesting Bob. So, if I am understanding you correctly, a load at a specific voltage will only draw the amperage specific to that load. Is this correct?
power supplies that have both voltage and current controls work in one of two ways.
Some have a mode switch that you set to constant voltage or constant current. When in constant current mode, it adjusts the voltage to achieve that exact current.
Others have a voltage setting and a current limit. In this case, the voltage stays at the setting until the current limit is reached, then it lowers the voltage to keep the current at the limit.
Bob
