Help with crystal timed circuit
How many circuits have you built.
  • 0
    Votes: 0 0.0%
  • 0-5
    Votes: 1 33.3%
  • 5-20
    Votes: 0 0.0%
  • 20-1000
    Votes: 2 66.7%
  • Total voters
    3
  • Poll closed .
Hello all,
I am building a 1hz clock using a 32.768khz crystal, 4060IC, and a 4027IC.
I have built the circuit twice on a bread board driving it with a 9v battery and it works. I also have built the circuit 4 times on a circuit board with no luck. My last attempt is used the exact layout as in the schematic, which I got from hackers bench(crystal controlled 1hz based time clock).
I have no clue what is wrong. I am in desperate need of help and would greatly appreciate any information.
The component values are as follows:
LH IC=4060
RH IC=4027
R1=330KOHM
R2=6.8MOHM
R3=6.8MOHM
C1=33pf
C2=33pf
Y1=32.768KHZ
It's a bit strenuous to follow a circuit without a schematic (for those interested: the circuit is described here). Let me assume the top diagram is correct. Furthermore it looks ss if the solder job is equivalent to the diagram.
What do you mean by " I also have built the circuit 4 times on a circuit board with no luck" ? Does the circuit not operate at all? Does it work at the wrong frequency? Or what?
One thing that comes to mind when looking at this design is the absence of blocking capacitors for the ICs. Put a 100nF ceramic capacitor from Vcc to GND directly at each IC, keeping the leads as short as possible.
