NewsClient
Hello all,
I have a five year old son who is blind. I am working on a project to make a
Braille printer for him, so we can 'translate' a lot of childrens books to
Braille. I have most of what I need figured out, running a PIC
microprocessor from a serial connection or parallel connection (supports
both, using a PIC 16f877 because I had them onhand.) What I need to figure
out it the best method for actuating a 'punch'.
If you are not familiar with it, Braille is a 3x2 cell (matrix) of raised
dots. Dot size is approx. 0.45 mm, with 2.2 mm intercell. Something like
where each * is a dot.
I have looked at two main ideas, one as a dot-matrix type printer, the other
as a 'typewriter' or 'daisy-wheel' printer. I am trying to determine the
best 'actuator' to pound the punch into the paper. I want to be able to
support clear plastic (known as Shrinky Dink or Grafix Shrink Film). This is
pretty sturdy stuff, so the 'pound mechanism' will have to be fairly robust
to stand up more than a week.
Yes, they do make these already. They sell for between $3K and $6K US. I am
saving up to get him one eventually, but am trying to do a little now with
what skills and tools I have available...plus, this is a great learning
experience on how to make these things (no, he does not use the soldering
iron, I do that.)
Please note, if the design works well, and is easy, I will post it public
domain for others to use.
Thanks for any ideas/concepts/opinions you would like to share on this
project.
Jonathan
iron, I do that.)
project.
Jonathan
