ok i did some tests that i don't quite understand, i tested the voltage at the main power point i got 4.35V, measured the resistance at the same point and got 1kΩ, meaning that the amperage is 0.00435A which i think is 4.3mA, P = I2 x R so I2 is roughly 0.07A and the power is 70W which if that's true it means i can put my speakers on there but i can't believe the amp is that powerful
Props for the attempt Tom, but the input resistance of the speakers won't be accurate or reliable.
The reason being, that the internal power supply for the speaker's built in amplifier will change it's effective resistance as the circuit demands less and more. The best source for this info is looking on or beside any power plugs or jacks and seeing if it will tell you an input voltage and input current. (Or output voltage and current if you have a DC wall adaptor)
From what was mentioned earlier, the amplifier we are referring to is the internal amplifier circuit built into the speakers. It may not say the power on the device anywhere, but it should at least have a voltage and current rating.
Without knowing, or being able to determine a guess at least, we can't recommend any reliable methods to add additional speakers.
One other note to add... Even if you add additional speakers, you may not get any additional volume as the amplifier that is in there is most likely loaded to, or pretty close to it's max rating.
